Results 1 to 10 of 25
Thread: Door 'cracks/clicks'...
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    confused Door 'cracks/clicks'...
    Hi all.when i open the drivers door you canhear a loud ' crack' or 'click' sound from what i think is the door strap...is this what its called?
    Im going to replace it cause its driving me crazy,or can it be fixed?...
    Mandurah, Western Australia
    It will be the door strap. I just had my passenger side one replaced. Not cheap, either. The solid metal strap itself was still perfect. But the plastic housing had worn away. So, a $100 part in the bin because of a 10 cent piece of plastic...
    WGAF#5
    wow = maybe we should export check straps to oz as there £13 -£15 here !!!
    Regular Member grumpano's Avatar
    North West
    Yep door strap mate
    West
    Check the bolts are tight & then try greasing the strap mech up first, if that doesn't cure it then fit a new one
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Tried the grease approach...gonna see if i can take it apart n see ...
    hull
    change the pin that goes betwween the strap and the body,any slight play will cause this cracking sound.
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    errrr....
    Too Right, Dez! Fifteen quid. Hmmm. Yep, A$100 - A$120 here. See, the 2003 CDXi (still not sure what they are called in the UK) in 5-speed auto cost A$50,000 new. That's up there with Audi A4 money. So, I guess the traders reckon it's an open slather rip-off. Plus, I think they only sold something like 4,000 of the 2003 Vectra-Cs in Australia (not sure if that's just the CDXi or all Cs in total). So they are relatively rare. I had already planned to buy parts from the UK in future. Like, fairly soon, the timing belt kit, water pump, oil/fuel/air filters etc. for the 120,000 km service. On that, can anyone tell me if the timing belt kits sold in the UK come with all the seals? Any other tips and suggestions? Please let me know. Cheers to All.
    Gävle, Sweden
    What's the GM p/n for the door strap? Is it easy to replace? The clicking sound is probably the most annoying sound in the world.
  1. Just clicks :(
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th March 2012, 23:41
  2. Gel Coat Cracks....
    By Leemarksmith in forum Bodywork & Interior
    Last Post: 1st December 2010, 15:55
  3. cracks in paintwork!!!!
    By axe_sri in forum Bodywork & Interior
    Last Post: 21st March 2009, 18:01
  4. big cracks in my walls
    By daveloz1 in forum The 'Off Topic' room
    Last Post: 13th May 2008, 21:19
  5. Clicks on the key
    By OysterD in forum Engine & Drivetrain
    Last Post: 8th November 2007, 09:25
