Results 1 to 10 of 30
Thread: Auto gearbox oil
    Larkhall
    Default Auto gearbox oil
    Does anyone know what type of oil the 1.9 cdti auto box uses, and also how much VX take to flush and change it?
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    If it's AF40 6 speed gearbox that you have, the oil's P/N is 93165147, GM oil ATF AW-1. You can check the type of gearbox looking down, between the engine and the battery. You will see a metallic plate which says the gearbox type.
    Mar 2007
    Tamworth
    Why does it need flushing? That's only necessary when the autobox already has serious problems, even then a full overhaul is probably best.
    Drain/refill only replaces about 1/2 the nominal contents of the autobox.
    The oil specification is in the Service Booklet - not the Owner's Manual !!
    Larkhall
    I thought it would need flushed if the oil was getting changed.........
    edit: is the oil GL5 75W/90?
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    If it's the AF40 gearbox, the only recommended oil is the one that I wrote before. I used it in my gearbox.
    Mar 2007
    Tamworth
    Quote Originally Posted by T4M View Post
    NO !!!!
    That's for manual gearboxes and/or differentials, particularly limited slip diffs.
    It'll need to be an ATF - I just don't which one but Dexron 2 was needed for early GM autoboxes with Dexron 3 for more recent ones but it may have changed again.
    Mar 2007
    Tamworth
    Quote Originally Posted by Lao View Post
    Because of climate differences, and local preferences, there may be variations in recommendation from one country to another.
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    Never found another oil recommended for the AF40 gearbox. The only one is the one I mentioned.
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    has to be a type 4 gearbox oil like comma asw must be suitable for aisin warner gearboxes its usually cheaper to buy from toyota its the same stuff ask for type 4
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    I'm guessing from your profile that you've got the 5 speed box which makes it the AF33?
    From the Haynes manual, they say use VX part# 93160393 which, when I wanted some back in July 2008, I Googled the part # and it came back with the same stuff used in Saabs from Parts for Saabs. http://www.partsforsaabs.com/advance...words=93160393. You'll need a max of 4 litres as Haynes say to start with, IIRC, an initial fill of 3.0-3.5lt and then check the level on the dipstick. The filling and checking method is described in Haynes and it's too long winded to explain here.
    As VX quoted me £100 to change the AF33 oil in my 02 GSi, this was the only reason I bought the Haynes manual. £20 for Haynes plus £30 (in July 2008) for the oil (delivered price), so I saved £50 and knew the job had been done properly.
  1. Auto gearbox
    By maud2450 in forum Engine & Drivetrain
    Last Post: 13th November 2011, 17:13
  2. 2.2 auto gearbox
    By adiehitch in forum Engine & Drivetrain
    Last Post: 29th August 2011, 14:47
  3. auto gearbox?
    By no1golfer in forum Engine & Drivetrain
    Last Post: 24th July 2009, 22:09
  4. auto gearbox
    By cerbrious in forum Engine & Drivetrain
    Last Post: 17th July 2009, 20:04
vauxhall af40-6 gearbox oil
aisin aw six speed 3rd generation autobox use what type of gear oil
sales@partsforsaabs.com
aisin warner aoutomstic gearbox vectra 1.9 cdti
vectra c dextron 3
dexron 3 gearbox oil 1.9 cdti
vectra 1.9 auto gearbox oil
