Results 1 to 10 of 11
Thread: can i change my tyres
    edinburgh
    Default can i change my tyres
    Greetings all . i have a vectra 2.2 dti sxi and my tyres are 215.55 r16. on visiting my tyre depot they suggested 205.55.r16 as is stated in the vauxhall manual. is this tyre size right for my vehicle or should i keep with the size i have.
    many thanks
    Providing it is in the handbook, you can use either 205/55R16 or 215/55R16
    In the longer term 205/55R16 will be cheaper, but it won't make much difference
    Equally, you may end up with mixed tyres while you change from 215/55R16 to 205/55R16
    Personally, you are the customer, you asked for 215/55R16 and that is what they should supply
    Get a quote from blackcircles.com and compare if it is worth changing over
    Mar 2007
    Tamworth
    The DTi engine is quite heavy - I wouldn't be reducing my tyre size for the fronts if it were me - I don't have a manual to hand but it may be that the 205 tyres were only fitted to 1.8's as they're much lighter engines.
    Full Member Big Sig's Avatar
    Size has nothing to do with the weight of the engine, thats why tyres have load ratings. However it is important to check these are correct
    Mar 2007
    Tamworth
    Yes and no - it's certainly the Load Index which is important - but "bigger" in the sense of just one dimension different with all others the same WILL give a higher Load Index assuming the construction is the same.
    Quote Originally Posted by Ruperts Trooper View Post
    A tyre with a load index of 91 thats a 215/50/17 can withstand the same loading as a 91 155/65/13. Unless thats what you meant?
    Or is this getting very complicated with the area of the foot print/load per area/friction arguement?
    Exactly, the load index depends on the total vehicle weight divided by five
    This allows for one tyre to fail and the vehicle to be safely brought to a stop
    I could fit 91H tyres to my car, but I wouldn't want to be doing more than 50mph when one tyre failed, never mind two!
    Mar 2007
    Tamworth
    That's what I meant.
    205/55-16 are normally Load Index 91 while the 215/55-16 is normally Load Index 93.
    Ahh got ya
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can i change them? - yes you can.
  1. Tyres, due to change
    By jontymo in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2012, 11:27
  2. national tyres oil change
    By tyler boy in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2011, 19:27
  3. When do you change your tyres?
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 08:58
  4. Change of GSi Tyres
    By GSiLad in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2009, 08:51
  5. tyres due for change?
    By bloodworm in forum Suspension, Wheels & Brakes
    Last Post: 17th October 2008, 17:24
