Thread: GSi battery - yes it's cream crackered!!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default GSi battery - yes it's cream crackered!!
    Started the GSi this morning, the first time in a week and all was fine. Moved it into the sun to get rid of the snow and left it there for around 4 hours with the engine off.
    Just gone to start it again and all I got was the signs of a flat battery, a very fast ticking noise and the engine not turning over. Checked the voltage across the terminals and got 12.5v.
    Got a neighbour to jump start the Vec and it started no problem.
    So, car's up and running but when I measured the voltage across the terminals with the engine running, it was reading 22v .
    Now I'm thinking new battery time but what about the 22v when charging?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    22v would fry the car i'd check it and hope it's wrong
    Mar 2007
    Tamworth
    22v across the battery is the alternator gone faulty, not the battery.
    Don't use the car, get the alternator repaired/replaced.
    East Midlands
    Voltage regulator has gone you, need to replace alternator.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Having thought about the 22v this afternoon and reading your replies, the first thing I'm gonna do in the morning is double check the reading on my multimeter.
    I have a feeling that when I had the DC range set to 0-60v, I read a 1/4 scale deflection as 20ish when in fact I think, in hindsight, it may have been 15v.
    Will double check in the daylight. Thanks guys so far.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Update - now I've got a new digital multimeter, I've got the following readings @ -1 deg C:
    Across terminals after car has been left overnight, not started = 12.1V
    With rear screen and blowers on = 13.8 to 14.1V
    I think the 12.1V after standing indicates a duff battery - can someone confirm before I spend my Xmas pressie money.
    Mar 2007
    Tamworth
    13.8 > 14.1 with engine running and electrical load indicates the alternator is regulating properly.
    If the battery is simply flat from standing, then 12.1 in the cold is to be expected - but if the car's been used a reasonable amount then the battery isn't holding a charge.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by Ruperts Trooper View Post
    Strange thing is that having left the car for three very cold days without starting, it started perfectly today with no signs of having a weak battery. I was expecting the "click click click" again today but the engine burst into life as if it was a warm summers day.
    Mar 2007
    Tamworth
    Cold weather, poor conditions needing lights, etc, and not being used regularly can lead to a low charge battery.
    It might be time to invest in a "smart" charger, eg CTEK XS3600 £50 or Aldi/Lidl XS £13 - I have both a CTEK XS3600 and an Aldi XS - the CTEK is the better charger, the Aldi/Lidl the better value - each of these can be left connected permanently without overcharging a battery.
  1. Ice cream van wars
    By Даниил in forum The 'Off Topic' room
    Last Post: 10th October 2012, 19:12
  2. is my cat cream-crackered
    By signumturbo04 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2010, 09:50
  3. Ice Cream Van.
    By KC in forum Comedy & Humour
    Last Post: 31st January 2009, 19:27
  4. What to use on cream leather
    By steve1975l in forum Detailing and Car Care Discussion
    Last Post: 26th September 2008, 17:13
  5. Drop links - cream crackered at 19 k miles !
    By omega2498 in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2007, 02:56
