Thread: vectra 1.9cdti clutch noise?????
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Exclamation vectra 1.9cdti clutch noise?????
    i have just bought my vectra sri 150 estate and i love the car so much much better than my previous mondeo.
    its under warranty for the next 3 months but i have noticed that when i depress the clutch it has a noticeable rattling noise but when its not depressed its fine the car pulls well and there is no clutch slip
    whats the problem could it be a release bearing or flywheel or the clutch itself any body can help me please then this will be good thanks.
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Reading previous posts on here, sounds like the DMF, pretty sure someone will 'firm it up for you shortly.
    Regular Member bradley's Avatar
    Hartlepool
    THE DREADED DMF ARRRRRRRRGH, im having same trouble it cost 800pound for parts for my 2002 2.0ltr Dti, should be around 200pound area for your car though matey
    kings lynn, norfolk
    finally got my car to the garage after a number of probs spoke to the mechanic today and told him what is wrong and they have all the parts on order and they are all getting replaced under my 3 month warranty lol thank god
    things getting done are
    dual mass flywheel and clutch change
    complete new inlet manifold with swirl actuator
    new thermostat with temp sensor
    new alternator
    and new wind mirror with new motor
    alot of money that the warranty company will spend on an 06 plate 1.9cdti 150 sri estate with 64000 miles
    i wonder how better my car will run after its fixed.
    will let you guys know and thanks for all your help
  1. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  2. Vectra C 2.2 DTI Clutch/Gearbox noise problems
    By Gramoz in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2012, 14:13
  3. Vauxhall Vectra C 1.9CDti Whining noise!
    By ibz in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2011, 18:04
  4. vectra cdti noise on clutch
    By hitcho in forum Engine & Drivetrain
    Last Post: 11th July 2011, 00:01
  5. vectra 1.9cdti gen clutch
    By vecdti in forum Parts for sale
    Last Post: 16th November 2008, 22:24
vectra c clutch noise
vauxhall vectra clutch making noise
vectra c 1.9cdti clutch
vectra c cdti clutch rattle
vectra cdti clutch noise
vectra cdti thrust bearing noise
vauxhall vectra c 1.9 cdti clutch thrust bearing
vectra c 1.9 cdti clutch bearing
vectra clutch release bearing
engine noise when clutch pressed vectra sri 1.9
1.9 cdti clutch noise
vectra cdti clutch bearing noise
vectra c clutch release bearing
how do you know when clutch is slipping on a vectra 1.9 cdti
https:www.vectra-c.comforumshowthread.php97790-vectra-1-9cdti-clutch-noise
vectra clutch whineing noise
my astra 1.9 cdti makes a noise when i depress the clutch
vectra sri 1.9 cdti problems air noise
