Thread: Stubborn Front Brake Disc
    Nov 2009
    midlands
    Default Stubborn Front Brake Disc
    Hi All,
    I was wondering if anyone could offer me some good ideas on how to remove a very stubborn front brake disc !
    I have replaced the off side disc and pad without any hassle, moved around to do the near side, removed the caliper, carrier and disc retaining screw, and despite using some mild violence onto the disc using my dead blow hammer, lump hammer, and finally my hub puller, the disc will not budge.
    I have soaked it in wd and will be leaving it overnight to soak in ready for round 2 in the morning.
    Does anyone have any other ideas ? I've had discs that needed a little gentle persuasion but nothing like this before !
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Big hammer!
    It'll either lossen off or smash into pieces and fall off, I had to do that with a freelander I changed discs on
    Regular Member Jezzy's Avatar
    S.E
    On the disks I've changed, they either come off straight away (because the last fitter used copper grease on the hub) or they require heavy violence - mild violence won't cut it. I have heard that there's a possibility of damage to the hub that way, but I don't know if that's just talk.
    I've also heard (but never tried myself) that on some cars there's an extra hole in the disk, with threads cut into it, just like the holes for the wheel bolts to go through, but the purpose of this extra one is to screw in a wheel bolt and the tip of it will be forced against the hub, thus forcing the disk off. I can't remember if Vec-Cs have this or not.
    East Midlands
    If you have access to a hot air gun or blow lamp..try a bit of heat on it bud,and then use the persuader Big Hammer.
    Jul 2009
    sussex
    definitely use some heat.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    try cutting striaght down through with a hack saw and then hit it hard as you can with the biggest hammer you have.
    or try heat
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    i had to use a lump hammer on one of mates on his pass side thought going to smash the hub the way it was welded on ... give it a few hard wacks the turn disc 180 deg and repeat it will come off in the end
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    Agreed... on my old cougar I snapped the disk with a big Landrover Disk puller... so resorted to hours of violence. Its only when I got the big hammer to it and risked the car falling off the axle stands onto my 'fat sward of a heed' that it finally broke free!
    Nov 2009
    midlands
    Well I've spent another day attacking the disc with my lump hammer and it hasn't budged a mm. I haven't got a torch to hand to try heating it up, and the only other way I can think of getting the ****ing thing off is by cutting the disc, however I don't want to risk damaging the hub (as it's a sealed unit I dread to think how much VX would charge for a new hub assby)
    I'm going to have to bite the bullet and speak to my local garage to see if they can do something with it asap.
    Thanks guys for your suggestions, it's much appreciated
    Where abouts are you mate I the midlands? I'll be passing that are tomorrow and two people might be better than one...
  1. Broken front brake disc
    By Gethda in forum Suspension, Wheels & Brakes
    Last Post: 8th July 2012, 10:27
  2. For Sale: Front Brake Disc and Pad Set - 93186298
    By Rossy in forum Parts for sale
    Last Post: 5th August 2011, 12:36
