Results 1 to 10 of 16
Thread: Diesel cold starting??
    Jun 2009
    Chelmsford
    Default Diesel cold starting??
    During this cold spell we are in the vectra has taken a bit longer to start in the mornings, so just wanted to know is there a particular starting knack for these in the cold? With my old Jeep used to turn on ignition until glow plug light went out then fire her up, sometimes had to give it 2 turns on the glow plug, but dont seem to have a glow plug light on the vectra, any tips??
    Quote Originally Posted by Governor View Post
    I would start with that, as it should briefly appear when you turn the ignition on
    That may suggest the glowplug relay has failed, and you need this attended to ASAP
    Regular Member P3tchy's Avatar
    Milton Keynes
    If the glowplug light has not come on then its not cold enough for it yet, even this morning when it was -3 my light only came on for a second. normally just start it straight off the key.
    Leicester
    It is usual for this to happen on these cold days, mine does it and the glow plug relay is fine.
    I have found the best thing is to switch on the ignition, once the coil light goes out, still leave it for a few more seconds then it will start pretty quickly.
    I would say you have nothing wrong and it's just the usual issue of diesel engines and extreme cold (Extreme for the UK anyway!)
    Riga, Latvia
    agree with that.
    There are something wrong if you can't see glow plug light.
    It appear always (depending outside temperature - shortly or for longer time). Maybe just glow plug light bulb burned out.
    it's cold these days, where i am living. -10 to -14 at day , and -16 to -22 at nights.
    My 3.0cdti have no problems. Just wait for some sec until glow plug light went out and fire up.
    Edinburgh
    Quote Originally Posted by Maverick View Post
    Quote Originally Posted by P3tchy View Post
    The glow plug light should appear briefly when starting the ignition (not the engine), even on a warm engine
    Equally, the colder it is the longer it should stay on
    I would expect to see it for at least 0.5 seconds, increasing to 1.5 seconds when below -5'C
    Regular Member paul.sessions's Avatar
    leighton buzzard
    yes i do this too it works
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    After 5 hrs in the cold my glowplug light don't come on
    Irmscher Insignia CDTI 130
    Sep 2009
    Glasgow
    might be overkill but I turn ignition and and off 2-3 times depenting on how cold it it each time waiting till coil goes out to ensure glow plugs are fully heated,
  1. petrol/lpg cold starting
    By murt690 in forum Engine & Drivetrain
    Last Post: 4th February 2013, 21:52
  2. misfire when starting from cold
    By bert01909 in forum Engine & Drivetrain
    Last Post: 15th August 2011, 19:51
  3. Starting in the cold
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:15
  4. Bad Starting From Cold
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 7th October 2008, 11:48
