Thread: Gear change massive problem
    Aug 2009
    ayrshire
    Default Gear change massive problem
    Hi guys once again I require your help and advice with my 03 vectra.
    My problem is in the cold mornings I have trouble selecting a gear and I mean I cant get a gear not one its very very stiff to go in but once driving for a while its fine. its becoming a real pest as I have to select 1st or reverse whilst the engine is of, the gear selection is normal when engine of but as soon as turn engine on I have real bother selecting a gear.
    Its driving me mad as sometimes I have to turn the engine of at junctions to select 1st. Its not just going up the gears but also down them as well.
    Any advive or help is much appreciated.
    Regards to you all
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    Gear box oil level? Clutch system required bleeding? Is the clutch "bit" at the same level all the time? To start with.
    Jul 2006
    TENTERDEN KENT
    Next:- Clutch fault, worn synchroniser cones, worn or missaligned gearchangs links, first two MONEY!!!!
    Oct 2007
    Shropshire
    When your moving, double clutch and blip the engine revs and it will help it to go in.....
    Oct 2007
    Shropshire
    Oh and some cheap honda civics don't have syncromesh on first gear (not the latest model the one before) and are like that all the time anyway. My friends is terrible...
  1. massive but strange problem
    By vectraryan in forum Electrical & ICE (including SatNav)
    Last Post: 29th April 2011, 18:01
  2. gear change problem
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 19:43
  3. A Massive Change
    By infernalant in forum Introduce yourself.
    Last Post: 19th October 2010, 18:04
  4. Gear Change Problem
    By Goby_Won in forum Engine & Drivetrain
    Last Post: 28th February 2010, 22:19
  5. Massive problem/s. Vectra c 06 plate 3.2 v6 sri
    By vec3.2 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 17:08
