Thread: Peed Off, Stupid Car
    Regular Member Clugie's Avatar
    Jun 2009
    Liverpool
    Angry Peed Off, Stupid Car
    was drivin home from work everythin was fine went to the petrol station put diesel in, the pump didnt feel right when i was putting it in an i did check it was diesel pump, it was my normal station that i normally go to then drivin home after that an i put it into 5th an the car started juddering as if ide put it in a high gear with low revs, i geard down an it was still doing it then it went back to normal, then picked the mother up from work everythin was fine for a 30 min drive, went to my mates sat in his for 15 mins the decided to go out put the key in started it put went to reverse an the revs were going up but very slow so i kept it reved an then it went normal then i drove it round the corner to mine an then the car an spanner light cum when i pulled up, then put my foot flat on the accelarator and it went even reving up? took my tuning box off still no change? apart from the exhaust had crap cumin out of it when it didnt before this happend, anyone had any problems like this before??
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    do you think it could be the diesel?
    Jun 2009
    Liverpool
    Quote Originally Posted by chris1804 View Post
    That was my first thaught, but its just the normal diesel that i put in
    Oct 2009
    Sandwell
    Quote Originally Posted by Clugie View Post
    you never know could have traces of petrol in, remeber bedore petrol tanks used for diesel or somat like like that, how much diesel did you fill up?
    Jun 2009
    Liverpool
    i only put 12 pound in because thats all i had on me, i had just under a quarter tank
    Oct 2009
    Sandwell
    how about some fuel cleaner, or ive hurd on here somat about if you disconnect the battery for 30 mins it resets the ecu of faults and see if it still does it, dont forget radio codes and all that
    i tend to use v-power diesel now i know its more,
    Regular Member BoroDave74's Avatar
    Attleborough
    I can't help as to the nature of the fault, other than to suggest you get the code read ASAP.
    But with regards to the potential cause, and what you should do next:
    Ring the petrol station up, they will possibly confirm other breakdown and/or complaints. Obviously, if there is a problem with the diesel you will not be the only person to suffer.
    You can also ring Consumer Direct on 08454 04 05 06 to register your complaint. They will pass it on to Trading Standards for your area, Sandwell I guess, who will be more able to act should they recieve a group of complaints about fuel contamination or fuel quality issues. This will help if the fuel is the problem.
    I see you have a 1.9 cdti Vec, is it the 16 valve engine? The symptoms you have described are similar to what happens when the electrical connector on one of the fuel injectors becomes a bit dodgy, usually the plug on No 3 injector. Vauxhall sell a short bit of wiring loom to repair this as it is a known fault on the 1.9 engine. I may be totally wrong here but its worth checking if the injector plug has ot been replaced in the past.
    Edinburgh
    this happened to me. It starts off slowly then eventually eml and limp mode follow. Check your connectors to see if they are blue or yellow. Reading the codes would also help diagnose.
    Jun 2009
    Liverpool
    Couldn't be botherd messing around with the car so rang the garage an they picked it up at 8.15 this morning, just hope i have it back for christmas an its somethin simple an cheap to fix.
  1. Currently extremely peed off !!
    By aps in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 17:20
  2. now getting peed of!
    By twaiter in forum Engine & Drivetrain
    Last Post: 29th June 2009, 12:37
  3. I'm really peed off!!!!
    By Jay Kay 313 in forum General Chat
    Last Post: 4th September 2008, 11:03
  4. stupid stupid stupid question- 3.0dti badge
    By Adamdavi3s in forum Styling
    Last Post: 17th August 2007, 06:32
  5. I am peed off, its official
    By wrightgj in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2005, 07:59
