Thread: Engine Juddering and struggled to reach 70 mph
    Regular Member vectrasri-j's Avatar
    Sep 2009
    luton
    Engine : 1.9 CDTI 120
    Mileage : 100000
    Default Engine Juddering and struggled to reach 70 mph
    hi, got onto the motorway today and the car started to judder at around 45-50mph pulled over on the hardshoulder and stopped and started engine problem didnt go away there was no engine mangement light, tryed to reach at least 80mph but the car was really strugling at around 65-70mph, when i finally got home topped it up with some antifreeze and took it back on the motorway everything was fine car wasnt juddering and took it to ***mph without any problem. anyone know what this problem could have been and is it likely to re-occur?...Also id like to know what precautions or checks people are doing to their 150cdti for the cold weather?
    Sep 2009
    Audley STAFFS
    strange one,, maybe waxed fuel.
    Regular Member CDTi Mike's Avatar
    Dec 2005
    Melksham, Wiltshire
    Possibly No3 injector wiring?
    Unless you've already had it re-wired.
    Sep 2009
    luton
    Mileage : 100000
    that is what i thought the problem could of been, the 3rd injector hasnt been rewired on my car. does anyone know how much Vx charge for part and fitting? Cheers
    Dec 2005
    Melksham, Wiltshire
    Sorry, not sure on the price of parts / labour as mine was done under warranty for the exact same symptoms you described.
    Just found a How-to, this would be cheaper than getting Vx to do it and i'm fairly sure the parts will be less than £20.
    LINKY
    Oct 2009
    Teesside
    Yeah do it yourself and it will only be £12 for the parts!
    Does sound like the injector problem mind, would get it done soon as possible, I did mine as I was getting juddering at aroun 1800rpm.
    sweet as a nut now
    Sep 2009
    luton
    Mileage : 100000
    any specific tools i will require to do this on my own?? thanks for the help guys
    Edinburgh
    just a soldering iron if memory serves. I did this on my vec, cheapest fix ever
    Sep 2009
    luton
    Mileage : 100000
    thanks for your help guys, will be giving this a go tommorow if Vx parts are open tommorow
    Regular Member bradley's Avatar
    Hartlepool
    how do you know its injector number 3?? mine judders at 1500+ revs could this be my injectors??
    thanks
    oh and mines a vec 2.0ltr dti 2002
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Engine fault light on / Juddering when hot
    By Angelchops in forum Engine & Drivetrain
    Last Post: 17th September 2011, 19:16
  3. Vectra 2.0 DTI STRUGGLED
    By danny1992 in forum Engine & Drivetrain
    Last Post: 20th October 2010, 14:32
  4. Starting - engine juddering
    By GWHIZZER in forum Engine & Drivetrain
    Last Post: 16th July 2009, 14:50
  5. Engine Problems again Spanner and juddering !
    By CdRsKuLL in forum Engine & Drivetrain
    Last Post: 6th December 2007, 22:27
