Page 1 of 11 123 ... LastLast
Results 1 to 10 of 101
Thread: Wipers Misbehaving...
    Sheffield
    Default Wipers Misbehaving...
    Hey,
    I am having a problem with the wipers on my 06 Vectra.
    I have read some similar posts oo here but they differ from my problem.
    Normally when I press down on the wiper stick it wipes once, but as of this morning (icy) I have to hold the stick down. If I let go, the wipers stop immediately.
    Also, when I press the stick up once it is normally intermittent, then up again for normal, and again for fast. Now if I press up once the wipers miss the intermittent step and they are on normal.
    When I try and pull the stick towards me to spray, nothing happens at all.
    Does anybody know what the problem could be? It was -3 when I used the wipers this morning... but I did make sure they were clear of ice before. Has this broken them?
    Jul 2009
    sussex
    id leave it all to thaw out and try it again.
    Regular Member petel's Avatar
    Nov 2007
    bristol
    mine was the same this morning (showing -7 on my weather station wind chill) ,checked later on all back to normal
    Regular Member no1golfer's Avatar
    Jul 2009
    newcastle upon tyne
    same here.obviously the standard vx stuff.
    Rotherham
    I was just about to post with the same problem! I took it to the dealers yesterday but they couldn't find a problem. They went back to normal when I tried later in the day. I had the same problem this morning though, -3 temperature. it's booked in for Tuesday.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I posted something on here with no reponse when mine did it a while ago... however found the problem!!!!
    Mine worked this morning at minus 5 when it was icey.. however so did my washer pump. They carried on working all day til it dropped to minus 7.. tried to clear windscreen and it was frozen, after a few attempts the washer motor stops altogether.. and then the wipers dont self park!
    I think there may be one of those fuses that can break then reapply like a circuit breaker? Havent had a look but somehow the car cuts off the circuit to the washer pump when its not able to spin? It worked again later when the washer fluid had thawed.
    I could be wrong but that seems to be the case with mine anyway ur not alone
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    ...........I should have read this before freezing my Brazils off pulling fuses
    Bordon, Hampshire
    I would like to mention that none of my washer pumps work anymore by the way... lol! Although it was minus 25 last night, and hasnt topped minus 9 so it could be why. Even the undiluted 1:5 screenwash I had in the shed was frozen :O
    Regular Member Lump's Avatar
    coventry
    have the same problem every time it gets really cold, but here is the solution
    http://www.vectra-c.com/forum/showthread.php?t=90019
    Bordon, Hampshire
    Quote Originally Posted by Lump View Post
    Hmmm I remember seeing that a while ago too.. but I dont think its the same problem. Surely everyones motors aren't packing up just because its got icey...? I think I will wait til its thawed out first.. hope and pray! Hope and pray!
  1. Autobox Misbehaving!
    By tnewbery in forum Engine & Drivetrain
    Last Post: 17th June 2013, 18:35
  2. misbehaving fuel cap locking mechanism aarrgghh
    By pogo in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2012, 14:51
  3. the signum is misbehaving,rattle coming from engine
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2008, 00:05
  4. 3.0 cdti auto box misbehaving
    By Davethemover in forum Engine & Drivetrain
    Last Post: 16th July 2008, 17:07
  5. cars misbehaving a wee bit!
    By pogo in forum Engine & Drivetrain
    Last Post: 21st November 2007, 12:39
