Results 1 to 10 of 19
Thread: Thermostat
    Oct 2009
    N.Ireland
    Default Thermostat
    Hi all, Yesterday i changed the thermostat on my 1.9 cdti 120 veccy (71k) on clock. I changed it because the enginge temp never read above 75 on the gauge and i was told normal was 85. It only ever read 75 even after the engine was warmed up say even after driving it for an hour. But changed the thermostat and still it wont read higher lol still sits at 75. So question is, is this normal or do i have a fault somewere else?
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds normal bud
    Oct 2009
    N.Ireland
    Serious? lol so i replaced the therostat for no reason? My mate has a veccy with the same engine and his always reads 85 lol strange!!
    Regular Member axelf's Avatar
    chester le street
    Hello m8 i have the 120 too, my temp never got higher than 76, changed the thermostat (what a b"£$^&d of a job) and now it runs at 86...........have you got an air lock???
    Oct 2009
    N.Ireland
    Quote Originally Posted by axelf View Post
    **** of a job mate! Possibly how would i check?
    Last edited by bigmac; 20th December 2009 at 23:22. Reason: please use the swear filter in future
    London/Essex
    To eliminate an air lock remove the right hand (when facing it) heater hose while filling the system with coolant via the expansion tank, replace when coolant flows out. Also bleed the system via the bleed screw on the coolant pipe above the exhaust manifold.
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    One question: do you have to entirely remove the little screw?
    Oct 2009
    N.Ireland
    Thanks for the replys, i didnt do the termostat my self just watched lol i know nothing about these cdti lumps to be honest was so used to working on my petrols, wish i had my old astra back lol
    Its startin to annoy me now, just drove 30 miles and it didnt heat up at all, il be dropping it in after the holidays to get sorted.
    Oct 2009
    Teesside
    Still sound like a dodgy Thermostat to me, did you replace it with the new or or accidently put the old one back on lol!??
    Could be possible that you got a dodgy thermostat from the dealers??
    Apr 2009
    Skelmersdale
    \i have a 120 , Mine takes a good 10 minutes before the needle starts to move and usually just gets above the 80 mark..
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
