Results 1 to 3 of 3
Thread: Gear stick problem
    Cambridgeshire
    Default Gear stick problem
    The gear stick in my vec facelift cdti 150 has gone sloppy! The gear stick won't return to the centre when out of gear. I've had a new clutch and dmf fitted before I bought the car and I think that the gear return linkage has not been put back on correctly .
    My mate (who I bought the car from) phoned the garage where the work was done and was told "Sorry, bring the car back and i'll fix it, it's an easy job" Problem is that the garage and my mate live over 100 miles away!
    I'm fairly handy with the spanners if told what to do , so I was wondering if this is an "easy job". Can the linkage be got at from inside the car or will it need to be on a ramp?
    thanks for any help.
    Dave
    Cambridgeshire
    Right, I've had the problem looked at and I've been told that a pivot pin on the linkage bracket on top of the F40 box is seizing up. The garage contacted vxl to ask about a replacement and was told they (vauxhall) don't do them and I would need to get a new gearbox .
    The garage was as shocked as I was, so they have tried to clean and lubricate the linkage which has helped a little. But the problem still exists and is really pee'ing me off.
    Has anybody else had this problem and managed to cure it, without having to replace an otherwise perfect gearbox?
    Please help as I'm at my wits end with this.
    Cambridgeshire
    thanks for all the advice, i've been overwhelmed!!
  1. For Sale: vxr gear stick
    By happypostie in forum Parts for sale
    Last Post: 22nd January 2012, 20:17
  2. Gear stick going into neutral problem
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 8th January 2012, 10:52
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
