Results 1 to 10 of 15
Thread: Possible to disable ABS?
    Bedfordshire
    Default Possible to disable ABS?
    As it looks like I'll be having a snowy drive to work tomorrow I'd quite like disable the ABS on my Vectra to give me some change of stopping at junctions. I've got access to the Vauxhall TIS system, so tried to trace a way of disabling it from there. When I pulled the fuses which seemed to be correct it just stopped the engine from running.
    Can anyone give me any pointers on how to disable the ABS if I haven't got a switch, specifically which fuse I could try pulling?
    ETA:
    Car is a 2003 2.0T SRi..
    Last edited by MarkySparky; 17th December 2009 at 20:13. Reason: Added car details
    Mar 2007
    Tamworth
    A front-wheel drive turbo isn't the best car to go out in the snow, not on "summer" tyres anyway.
    Don't worry about it - everyone else will have their ABS working - if you do manage to stop quicker than others, you'll just get rear ended !!
    Regular Member Keithy's Avatar
    Jan 2008
    Dundee
    Defo pull the fuse but aint got a clue which one. used to work on the old cavy's, but then again the system probably wasn't as complex as the vectra c
    WGAF#5
    modern cars can disable the vehicle from starting if it detects a serious fault on the abs - which is where your problem lies
    Bedfordshire
    Modern? It was one of the first 2.0Ts ever built!
    I know of the problems with driving a front wheel drive turbo in winter. I've owned the car since new so this is the 7th winter I've driven it. That's why I'm trying to disable the ABS. I still remember the feeling of helplessness from last winter when I was sailing over junctions with the brake pedal juddering! Wide tyres are not always good!
    If the fuse plan isn't going to work I'll have to keep my eyes open for a pothole to hit. That seems to send the ABS into a sulk these days anyway...
    Thanks for the help everyone.
    Melbourne, Australia
    You'll need the ABS system to have a working speedometer. I wouldn't encourage this, but maybe try disconnecting one of the non-driven wheel speed sensors.
    Mar 2007
    Tamworth
    Brake pedal juddering?
    The reason ABS is less effective in snow is because all four wheels lock simultaneously which confuses the ABS ECU into thinking that no intervention is necessary - in these circumstances the ABS doesn't cycle the brakes, same as a race driver not using ABS as it doesn't work in a 4-wheel lock up.
    If your brake pedal was juddering, ABS was working and NOT being confused by snow - switching it off will make stopping distances longer in the circumstances you describe.
    I do know a way of "disabling" the ABS but it would be irresponsible of me to make anyone else aware of it!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would not recommend disabling your ABS - you would be leaving yourself wide open to insurance issues if you needed to claim.
    Without sounding snotty, maybe improving your driving on snow skills would be a better option?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Quote Originally Posted by Ste View Post
    Agreed. Adjust your driving, do not approach any junctions at the same speed you would in dry conditions.
    The ABS also has the EBD function - helps stop you in a straight line!
    Regular Member benny's Avatar
    Feb 2006
    dudley
    the good news is removeing the fuse will kill / stop the abs working ......the bad news is beeing as it is the canbus bridge you wont be able to start the car so you wont beable todo any driveing .....simples ...lol.. ...just drive slower in the snow / ice ...
  1. Disable alarm?
    By TimK in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2012, 00:33
  2. egr disable 2L ??
    By dc6839 in forum Engine & Drivetrain
    Last Post: 22nd July 2011, 10:51
  3. disable egr 1.9
    By exvectra in forum Vectra C / Signum Troubleshooting
    Last Post: 6th May 2010, 17:32
  4. disable egr with op com
    By winnie2457 in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 20:13
how can i disable my abs brakes on vectra c
disable ABs vectra
