Thread: Having problems locking the doors!
    Regular Member bizerk's Avatar
    EDINBURGH
    Default Having problems locking the doors!
    Hi all, it been a while since I last posted on here, hope all is well!
    When driving my car, I get the symbol on the dash indicating that the drivers door is open, so when I try and lock the doors the locks go down and then just bounce back up again. The only way Ive been able to lock my car today is to lock all the doors from the inside and then lock the rear door last.
    Any ideas?
    My car is the 2003 1.8 LS Hatch
    Also is there a way of disableing the central locking for the time being so that I can just lock the drivers door with the key?
    Thanks in advance
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It sounds like the door switch inside the drivers door lock isn't functioning properly. This detects when the latch is properly closed, there are 3 positions - OPEN, latched, closed. It need to be in the closed position before the switch identifies it as such.
    Have you tried opening the door and with a screwdriver (or similar) manually moving the locking mechansim that would normally strike the catch to the full closed position and trying to lock the car? I would also try spraying some WD40 (or similar) into the locking mechanism.
    Remember to pull the door handle to open the latch before trying to close the door else you will only get a 'clunk'.....
    EDINBURGH
    Cheers for the super fast reply!
    Ive not tried anything yet as it only happened about 45min ago and its lashing down with sleet outsid lol
    I will try opening the door and closing the lock with a screw driver as you mentioned and see what happens.
    PS is it easy enough to open the lock again if its locked with the door open?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, just pull the door handle...
    EDINBURGH
    Cheers! Will give it a bash when the weather calms down a bit.
  1. Radio Staying on and doors not locking.
    By Robbiew.90 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2012, 14:42
  2. Doors keep locking?
    By rob10 in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 22:08
  3. Remote Central Locking - press open just once for all doors?
    By petesaysblimey in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2009, 08:54
  4. Auto Locking doors
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 10:22
  5. Auto locking doors
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 13:14
