Thread: Cluth and flywheel 2.0 Dti vectra ???
    Regular Member bradley's Avatar
    Hartlepool
    Exclamation Cluth and flywheel 2.0 Dti vectra ???
    hello my vectra seems to be juddering/shakey when driving although when i put the clutch in its seems to go smooth ( no juddering ) ???
    i have been told this could be the flywheel on its way out?? is that true?
    also how much would this cost for the replacement part? does anyone have a part number for this??
    thanks
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Flywheel on the way out? What do you mean by that? Isn't the DTi a solid flywheel and therefore the only realistic failure would be wear which shouldn't cause the symptoms you describe.
    Is it speed related or engine related? Are the engine mounts in good condition - try 'rocking' the engine and watching for movement.
    Are engine to gearbox bolts all tight?
    If the flywheel is dual mass (I can't remember if DTi ever had them) then it could be a sign that it is on it's way out.
    West
    The dti is a dual mass fly wheel & a common fail as with every motor all different makes that use a dmf
    Hartlepool
    Exclamation
    Quote Originally Posted by Ste View Post
    well i took my car to vauxhall main dealer today for a free test drive with the main technical expert and the first thing he said was it feels like its running on three cylinders, or an injector is nackered. basically he couldnt tell wat was wrong by just driving it but he DID rule out the clutch and flywheel he said in his opinion it defintly is not the flywheel...
    i have book my car in at vauxhall dealer on tuesday for a full diagnostic check and for the mechanics to have a good rummage around the engine for any faults which is costing me £40
    any advice....???
    Hartlepool
    well took my vec 2.0 dti 2002 to another garage today done a diagnostics check and no codes came up??? mechanic said the juddering at 1500+revs is 100percent DMF failure
    arrrrrrrrgh!! 1000pound to fix hahha i need a second hand / used clutch and DMF asap
    any ideas fellas
    Oct 2009
    preston
    Default oh dear
    ive got one to mate my flywheel was 340 and my clutch was 180 then fitting on top cheapest quote i got was 800 fitted with warranty were bouts u from
    Hartlepool
    Quote Originally Posted by mgp View Post
    Hartlepool up north near middlesborough. im thinking of finding a back end smash vectra with low milage and getting the clutch off that.....
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    hi mate
    thats my set which is completely ****ed if that can help you I did get
    my dmf and clutch from eurocarparts. I did push them very far with the price and all came on to 403 squidos and I got exactly what was factory fitted sachs dmf and Luk clutch ( comes with slave cylinder too ) then my good mate mechanic fitted them for me. Now clutch and gearbox feels a lot of lighter ( so as damn wallet )
    HTH
    Seb
    Liversedge, Westyorkshire
    hi there, how long did it take to fit the clutch and flywheel??
  1. For Sale: Dual Mass Flywheel VAUXHALL VECTRA 2.8 turbo 05-08, Z28 NET engine
    By viper8 in forum Parts for sale
    Last Post: 6th November 2012, 08:44
  2. Replies: 0
    Last Post: 25th September 2012, 13:44
  3. Vectra clutch flywheel kit
    By CristianTM in forum Engine & Drivetrain
    Last Post: 1st June 2010, 07:57
  4. Flywheel?
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 16:17
  5. cluth vibration
    By morphhprom in forum Engine & Drivetrain
    Last Post: 10th July 2009, 13:33
vectra c 2.0 dti flywheel
fitting a second hand clutch flywheel vauxhall vectra cdti sri
vectra 2.0 dti flywheel conversion
how long to fit a clutch vectra dti
vectra c 2.0 dti clutch change
vauxhall zafira 2.0 dti solid flywheel
vectra flywheel rocking
vectra c dti clutch change
changing dual mass flywheel to single mass on vectra c
vectra dti clutch for sale
dual mass flywheel and clutch vectra 2.0 dti
how much clutch for vauxhall vectra
does a vectra c 2.0dti have dual mass flywheel
is it worth converting clutch vectra c
Will a vauxhall vectra 1.9 cdti flywheel fit a 2.0dti
how long does it take to change a clutch on a vauxhall vectra dti
vectra c dmf change 20 dti
vectra c 2.0 dti dmf
does 2002 vauxhall vectra dti have dual mass flywheel
is vauxhall dti engine dual mass flywheel
vectra c 2.0 dti single flywheel
how to fix clutch on vectra c 2.0 dti
how to fit clutch on 2.0dti vectra 2004
Can i just fit clutch instead of replacing flywheel on 2.0dti vectra
