Thread: Had to fool car into starting!
    Apr 2008
    Northants
    Default Had to fool car into starting!
    Chaps,
    Couple of weeks ago during frosty weather, my 150 cdti wouldn't start and had a big 'F' on the display.
    Same thing happened today, frost weather, big 'F' (for frosty?), but i chucked some hot water into the grille where the outer temp sensor is causing the senso to warm up. Car roared into life!
    Its as if the electonics are saying, 'no you don't - its too cold. Brrrrrrr!'
    When it won't start, there is no mechanical movement, the electronics are stopping anything happening.
    Anyone have any ideas?
    LT.
    Birmingham
    You do know that if you scroll along the test where "F" starts it actually continues to read..OFF! In other words, its too cold, im a CDTI, wrap me up or I will not start, so " OFF!
    Bye bye Vec B
    - Hello Siggy!
    WGAF#5
    F= fault - i suspect your temp sensor is Faulty
    Apr 2008
    Northants
    Vaux-Man, you're a comedian! Same things have crossed my mind.
    I don't think the temp sensor is faulty as the temperatures it reports for the outside temp appear realistic. It seems like there's something making the decision not to initiate start on an incorrect temp level.
    I've had this car for 18 months now, through all the snow & cold last year with no probs. Now it seems when the outide temp dips too low, it goes on strike. It clearly can start OK, just needs lying to...
    WGAF#5
    Apr 2008
    Northants
    Thanks Deztroyer.
    From reading that, it sounds as if the sensor came unplugged from the loom - thinking back, my wife bumped the front end last spring, it may be falling into place!
    I'm a bit confused though, if the temp sensor was unplugged/faulty, how come i see accurate temps reported on the display?
    asdasd
    Because its a vauxhall..What have they ever done that makes sence...
    Birmingham
    Quote Originally Posted by vec3.2 View Post
    Make a CDTI 150 that is going to make them loads of money through dodgy and badly built manufacturer parts!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member clightowler's Avatar
    Oct 2007
    Leeds
    Trim : SRI hatch
    Engine : z19dth
    Mileage : 110000
    Quote Originally Posted by Last Turkey View Post
    Thanks Deztroyer.
    I think they are two different sensors that are used, it was on the vec b anyway hth
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Yeah the ecu gets its temperature readings from the coolant temp sensor. You could disconnect the one on the bumper and it would still start
  1. Not starting..... Possible Starting Motor
    By portreathbeach in forum Troubleshooting
    Last Post: 25th August 2012, 11:30
  2. CD30 Playing the fool
    By scotty84 in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2011, 15:16
  3. Have i made a fool of myself??
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2009, 14:40
  4. Fool proof tuning box 1.9 150?
    By Hideous in forum Diesel Engine related
    Last Post: 15th March 2007, 22:46
  5. Fool
    By 2ltrT in forum Comedy & Humour
    Last Post: 9th November 2005, 08:56
