Thread: steering angle sensor?
    Regular Member robwilson69's Avatar
    Oct 2009
    essex
    Default steering angle sensor?
    Steering angle sensor where is it???
    I read that cars with ESP it built in the CIM module ans cars without its in the rack itself, can anyoine confirm this? as i have non esp modle with IDS if this is correct where on the rack is the sensor?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    yep esp is in the cim all others in the rack .....but higher spec cars can have it in the cim too and not have any chassis extras best way to check is take a look at the rack on the drivers side and see if it has the sensor sticking out .......but i can guess from expirience you have a faulty angle sensor it is normally in the cim ....
    Oct 2009
    essex
    ok thanks i have sri 2007 2.0 turbo xp, but for some reason i dont think i have ESP fitted, i have noticed teh track rod arm drivers and track rod end have been changed by a previous accident so im thinking this is relation to the error i get on tech2 saying stearing angle sensor high or open circuit something like that, if i select calibrate sensor in CIM module with tech2 it says programming not possible, could this be because mine sensor maybe in rack not CIM?
    Oct 2009
    essex
    I have to mention i have separate pump under wing not one on the rack
    Oct 2009
    essex
    I been vauxhall today and the guy got me a rack for my car from teh stock room and trhe sensor is on there thank god, it makes things alot easier for me to sort hopefully..
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Does the angle sensor come seperately does anyone know or is it all part of the steering rack?
  1. Steering angle sensor
    By RichM in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2012, 20:22
  2. Steering angle sensor
    By Gregiboy in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2012, 14:11
  3. Steering angle sensor
    By 1979john in forum Vectra C / Signum Troubleshooting
    Last Post: 16th August 2011, 20:24
  4. Steering Angle Sensor
    By r.bailey63 in forum Suspension, Wheels & Brakes
    Last Post: 25th July 2009, 14:48
  5. Steering Angle Sensor
    By chanito in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2007, 18:12
vectra c steering angle sensor calibration
opel vectra c steering angle sensor calibration
vectra zc recalibrate steering sensor www.vectra-c.com
calibrate steering angle sensor vectra c
vectra steering angle sensor sticking brakes
angle sensor vectra c steering rack
