Thread: Boost Gauge now fitted !!! .....at last
    Regular Member bradley's Avatar
    Hartlepool
    Exclamation Boost Gauge now fitted !!! .....at last
    eventually got my gauge fitted and working fine, although i seen in another thread that at first when opening throttle the gauge reads 20psi then as the revs build up the gauge then drops and levels off at a steady 13-14psi, in that thread the bloke was told this is normal ( mine is doing exactly the same ??
    so the question i have is what boost am i actually getting? 20psi or
    13-14psi ???
    and also what is the recommended max boost i can set my vectra 2.0 DTi 2002 ? its totally standard ( at the minute ) no mods, chips or remaps??
    Hopefully someone can enlighten me and let me know the safe recommended max boost
    Regular Member paul.sessions's Avatar
    leighton buzzard
    we need pics
    Hartlepool
    Quote Originally Posted by paul.sessions View Post
    we need pics
    i will try and make a video and post it on PHOTOBUCKET then il put the link on here ok m8, but it will be hard as i will have to video the gauge whilst driving and keep my eyes on the road lol
    Glasgow
    its normal mate for the turbo pressure to go to 20psi and then level off at a steady 13-14psi, its called spiking if i remember correctly..
    my starlet used to do this dont worry matey.
    you should do a how to
    Hartlepool
    Quote Originally Posted by twaiter View Post
    i am gna stick a how2 as soon as i get a few pics uploaded m8, i really need to know what the safe max psi boost pressure is that i can adjust my actuator to..... 19psi should oryt i think but im no expert .... also im then going to SPIKING to about 26psi and levelling off steady at 19psi arnt i......? Advice on this Please thanks
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Glasgow
    yes mate its gna peak rather high if its adjusted, and if u change air filters etc u might get wats called boost creep which makes the pressure that bit higher..
    but as far as im aware you cant just get an adjustable actuator for these cdti engines its all controled via the ecu, and not alot of garages would put it past what they feel is safe to protect them selfs..
    why are you so keen to turn the boost higher?
    Martyn
    brum
    Try turning the nut on the actuator shaft a few times and see if it differs at all?
  1. Boost Gauge fitted
    By rockafella8587 in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2012, 17:20
  2. Boost gauge fitted..
    By Steven in forum Petrol Engine related
    Last Post: 22nd July 2011, 17:04
  3. Fitted Boost Gauge 2.0T
    By benholden2010 in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2011, 19:31
  4. VXR Boost Gauge Fitted....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 20:16
  5. Boost Gauge fitted
    By Jay Kay 313 in forum Styling
    Last Post: 12th September 2007, 22:23
