Results 1 to 7 of 7
Thread: Rear brake qestion.
    Regular Member Jekyll & Hyde's Avatar
    Sep 2007
    Walderslade Woods,Kent.
    Smile Rear brake qestion.
    Hi to all.
    Hoping you can help.
    The rears on my (56)150 are shot.
    I could replace them with standered running gear, or replace them with up rated running gear, but...... what i want to do is change them for the 3LD (292)set up.
    I had wanted to do the front brakes first, but the rears brakes have worn out first, & i'd hate to have to change them for standered stuff, & replace them latter with the 3LD gear, what a wast of £ it would be.
    Question is:
    Can i get away with replacing them with the 3LD calipers discs & pads, & replace the fronts at a latter date.
    If it is possable to do, where would be the best place to sourse the stuff ? (unless some one is selling some).
    Cheers
    Robert
    Sep 2007
    Please forgive the title spelling.
    It should have been "Rear Brake Question".
    Cheers
    Robert
    Regular Member Jezzy's Avatar
    May 2009
    S.E
    I don't see any problem with doing the rears first. Some people will tell you this will affect the front-to-rear brake bias, others will tell you that you'll need to adjust the bias on the master cylinder - but I'm not sure anyone will put their hands up and say they have ever adjusted it themselves.
    As for where to buy, your best bet would be to find them second hand, as the calipers and carriers will cost quite a bit. The disks and pads can be bought cheaply from Vauxhall, as they sell a £70+VAT "kit" which is 2 disks and 4 pads. If you buy the disks separate from the pads from Vauxhall, instead of as a kit, it's much more expensive. Hence the ideal plan would be to buy the calipers and carriers second hand, and add on the new disks and pads.
    Mar 2007
    Tamworth
    Vehicle : Skoda & VW
    Trim : Octavia SEL & Touareg SE
    Engine : 2.0 TDi & 3.0 TDi
    Year : 2016
    Is the master cylinder bias adjustable on a Vauxhall? That's very unusual for a road car.
    The rear setup isn't actually that expensive I think. the calipers are about 50 quid each i think, carriers 30 each and the pad and disc set maybe 60 quid depending on where you go. A bit of a poke around car Parts Connexion might help, as there was some good stuff on there in relation to all this last time I checked.
    Part Numbers:
    Caliper RH: 93181407
    Caliper LH: 93181406
    Carriers x2: 93172189
    Disc and Pad set: 93186301
    Sep 2007
    Thank all for you replys.
    I found the calipers about £50-60 on the net each unknown brand, and the carriers from vaxhall are about the same price as the calipers brand new.
    I was looking at the ebc set up for the discs, & pads, as i'v used them before, discs £85, pads just under £50.
    Cheers for you help.
    Is the part numbers in the previous post vauxhall No.?, also are the numbers the same for Saab, if they are, best get in there quick, now saab has gone bust.
    Cheers
    Robert
    Yup, they're VX numbers. Don't know if the numbers will be the same for Saab parts, but the parts themselves will be identical...
  1. DIY Paint Job Qestion
    By john506 in forum Styling
    Last Post: 22nd February 2012, 07:15
  2. Rear Brake Pad Change
    By chrisom in forum Suspension, Wheels & Brakes
    Last Post: 24th September 2011, 19:13
  3. Rear brake pad help please !!
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2010, 17:46
  4. Quick qestion
    By RN37 VXL in forum Bodywork & Interior
    Last Post: 23rd January 2010, 15:15
  5. rear brake pads
    By swainey in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2009, 21:23
