Thread: Are all glow plugs for DTi the same?
    Full Member fikse's Avatar
    Apr 2009
    Bergen, Norway
    Default Are all glow plugs for DTi the same?
    Have a 2.2DTi 2004, time for changing the glow plugs now. Have seen a pretty good offer on ebay but will they be the best match for my engine? Anyone have experience with the DTi engines? Are the glow plugs the same for all DTis?
    Bent, my name is Bent
    Mods: I polished it in september...
    Oct 2009
    Swindon
    No not buy cheap unknown make glowplugs.....better to get the best you can, will save time and money in the long run.
    I bought mine from GSF (German Swedish and French) for my 2.2DTI they are Beru? I think and came out at £30 for a set of four. If your unsure use the Euro Car Parts website as you can find the correct parts by using you reg number.
    Nottinghamshire
    Go for good plugs from a good manufacturer and replace all 4 - any that haven't failed will do soon due to sod's law.
    The plugs will be in there for ages so you'll get your money's worth out of them. I went for NGK and they have been abolutely fine. They were about £30-40 for 4.
    http://www.ngkpartfinder.co.uk/
    Apr 2009
    Bergen, Norway
    Damian; Did you click on the link I made in 1st post? Do you mean Bosch Duraterm is no good? Then I would like to know why...
    Oct 2009
    Swindon
    Sorry, no i meant dont buy cheap and nasty versions, buy quality branded items. Beru make OEM glow plugs but likes of NGK and Bosch will be as good.
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by damian s View Post
    Ahh, OK
    Then, I still hope that someone here can "enlighten me", wether its the same plugs on all yearmodels DTi or not...
    Nottinghamshire
    I would think they remained the same throughout. but you need to check. Does the NGK partfinder list more than one part for your car? In any case, a good supplier will be able to tell you which ones are right for your car whichever make you go for.
    Apr 2009
    Bergen, Norway
    Quote Originally Posted by James24 View Post
    Ahh, of course! The NGK partfinder should give a hint, huh?!
    Well yes, the plugs seems to be the same all the way. Both Vectra B/C, Zafira and Astra use all the same plugs on both DTR/DTi-engines, except for some of the oldest 2.0 engines.
    Good, cause these Bosch glowplugs where pretty cheap
  1. Glow plugs?
    By SEANYboi in forum Engine & Drivetrain
    Last Post: 11th February 2013, 10:00
  2. Which glow plugs for 1.9 150?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 12:01
  3. Glow Plugs
    By RobW in forum Engine & Drivetrain
    Last Post: 18th March 2011, 20:05
  4. Glow plugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 9th September 2010, 11:52
  5. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
Tags for this Thread
