Thread: "Safeguard Check??"
    Jun 2009
    Co. Durham
    Default "Safeguard Check??"
    Does anyone know what the message "Safeguard Check" means - with a picture of the safeguard system on the display?
    I am getting this sometimes when I start the car (06 Plate Veccy Estate).
    I cant find anything in the manual.
    I have had alarm problems of late and was wondering if it means that the alarm has been activated since the car was last running (in which case my neighbours may have been losing a lot of sleep!).
    I have recently had the rear side boot panes replaced under warranty and just had the relay replaced today. Only the rear shield pane left to go until the list of possibilities is exhausted, but this isnt covered on warranty as the inside of the pane is scratched, so before I go down this road I need to know what this message relates to!
    The battery unit has been checked on the siren and it isnt that causing the alarm to sound.
    Thanks!
    Regular Member P3tchy's Avatar
    Milton Keynes
    I'd check the safeguard..... make sure its still there.
    Seriuosly though... No idea. Probly a Tech2 job.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Safegaurd is to do with your alarm there maybe a fault code best to get it read,failing that it might be one of several things i had it once and i just disconnected my alarm sensors and plugged them back in and it was all fine afterwards
    But best bet is read fault code
    Irmscher Insignia CDTI 130
    Jun 2009
    Co. Durham
    As I suspected. Thanks.
    The rear side panes and relay were both replaced following tech2 reads, but there seems to have been some problem in isolating the exact cause of the fault - apparently there were some "erratic" readings coming off it. Will see if the message continues to come up following the relay change and get it back in for another read if it does.
    Hopefully will all be sorted before the end of January as the warranty runs out on the 31st!
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If its in warranty get it into them asap mate just tell them its popped up now and again and get them to check it all out
    Full Member spennny's Avatar
    Blantyre
    Also check your fuses located in boot area
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There's a common failure on the estates alarm mate. The glass breakage wire that runs round the rear glass gets damaged. I'd check that first mate.
    Worcs/Staffs/Westmids (ish)
    Next time don't steal a Vectra
    j/k
    Haven't knocked the sensor near the RVM hth ...........................
  1. Anyone know what a "SAFEGUARD" warning in info display means?
    By andy d in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2016, 21:00
  2. Screen showing "safeguard" ??
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 23:59
  3. "Check Safeguard"
    By hadiislam in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 13:59
  4. "Check Safeguard" on Display
    By BigMan in forum Electrical & ICE (including SatNav)
    Last Post: 14th March 2012, 21:07
  5. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
