Results 1 to 10 of 30
Thread: Checked the Swirl Bar and pots-think they are OK, please check!!!
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Default Checked the Swirl Bar and pots-think they are OK, please check!!!
    I started the car and rev'd it and the bar moves and so do the pots, so do I assume they are functioning correctly and are not contributing towards the lack of power sub 2k rpm.
    For those of you who arent familiar with me, its a CDTI 150 Facelift!
    See piccies below!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If the bar moves then its working ok, but looking at that picture it looks quite oiled and filthy and looks the way the my manifold did before it went.
    Gazza4
    Birmingham
    Its not fresh oil though Gaz.
    Regular Member nick_s's Avatar
    Jul 2009
    Stoke on Trent
    Is there much in the way of play up and down from the connecting bar? If so, it could well be contributing fella as suggested on the phone yesterday. Fingers crossed its not the problem, as IIRC you said that the manifold was replaced under warranty fairly recently.
    Birmingham
    Nick, doesnt seem to be any play, but then again, I didnt touch as the last thing I want to do is make it fall off! But it seems to be "swirling" freely. Yep mate, from our convo yesterday youa re right, the Swirl Valve and Inlet Manifold was replaced 2 years ago when we bought the car, so I dread to think thats its scuppered again!
    Regular Member barkzz's Avatar
    Looks ok, but fairly gunked up. My 4th swirl is getting gunked, but the other three are fine. I suspect it's the start of the knackered manifold scenario, as i recently had the EGR and 3rd injector wiring done under warranty, to cure:
    Poor startup/juddering
    Poor fuel consumption
    Smoking from exhaust when juddering
    On/off acceleration under full right foot (power dips off for a split second, then comes back on)
    No acceleration under 2k
    Birmingham
    Quote Originally Posted by barkzz View Post
    Poor startup/juddering - dont get this, only wobble on idle
    Poor fuel consumption - not considerably, mid-high 30's in town.
    Smoking from exhaust when juddering- none!
    On/off acceleration under full right foot (power dips off for a split second, then comes back on) - only sub 2k rpm
    No acceleration under 2k - THIS IS THE BAD BOY!
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by Vaux-Man-G View Post
    I have this on my car too!!!!! Me thinks I have the same problem as you Vaux-Man...The only difference would be that I've a 3.0CDTi and not a 1.9.
    Birmingham
    Quote Originally Posted by Celes View Post
    I would assume the problem behind it would be the same, if not similar?
    May 2007
    Norway
    I had the intake-manifold replaced under warranty a while ago, as I saw it was leaking in the same manner as your Vaux-Man-G. I was thinking that since there was a leakage there, it would affect the power as pressure in the intake (generated by the turbo) would leak out.
    Intake replaced, and new one does not leak. So far so good.
    Still felt some problems with low power at low rev's.........Typically under 2k. Then cleaned my EGR (not completely clogged, but had severe amounts of soot) and inserted a new flow-limitation gasket, cleaned the BoostSensor (it was really durty!!) and also the MAF-sensor got a clean. All is good now and has been for the last 8 months. That did the trick for my Veccy.
  1. Are my swirl pots leaking?.
    By felixx in forum Engine & Drivetrain
    Last Post: 2nd August 2010, 21:15
  2. Manifold swirl bar/pots
    By rob123 in forum Engine & Drivetrain
    Last Post: 1st June 2010, 18:58
  3. 2.2DTi blue smoke after fiddling with "swirl pots"
    By Celes in forum Engine & Drivetrain
    Last Post: 19th March 2010, 00:45
  4. cleaning the swirl pots
    By monty2000 in forum Engine & Drivetrain
    Last Post: 16th March 2010, 14:28
  5. CDTI 150 swirl pots
    By crgv6 in forum Engine & Drivetrain
    Last Post: 20th June 2009, 13:24
