Results 1 to 10 of 21
Thread: Hids direct kit, quick question
    Regular Member TopRod's Avatar
    Liverpool, UK
    Default Hids direct kit, quick question
    Can anyone tell me if the vauxhall ultra 35w hid kit from HID-Direct.com comes with the rubber grommit for the hole that you have to drill through the cap behind the headlamp? To keep the unit air tight.
    the ones that are just under the bulb moulded around the wiring? I am only asking as this is the H1 kit.
    Also does this kit just plug stright into the OEM socket which would go onto the standard halogen bulb?
    I have the standard headlight units (non HID) on my 07 SRi vectra, if you have the same and you have fitted this kit did it change the beam pattern? (have you noticed any glare at all or been flashed?)
    Thanks for any info.
    Last edited by TopRod; 15th December 2009 at 21:05. Reason: fogot to ask somthing.
    Regular Member Daywalker's Avatar
    Aug 2007
    Virbaliskiu km, Kaunas raj
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    Yep the rubber grommet underneath the bulb seals the hole.If you have a rubber cap then you can use a pound coin and go round it with a sharp knife you will find it makes the right size hole. HTH
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I also used silicone sealent ...overkill maybe but what the hell..
    Aug 2007
    Vehicle : Volvo V50
    Trim : SE Lux
    Engine : 1.6 Drive
    Year : 2011
    Just read the other bit in your post.The kit is just plug and play so easy to fit.It would be best to get your headlights checked after fitting for alignment shouldnt cost more than a tenner.
    Liverpool, UK
    Quote Originally Posted by Daywalker View Post
    I would have thought an MOT tester would not test that because they are not leagal.
    Liverpool, UK
    Also does this kit just go straight into my car no problem ( no eroor messages or flickering or shutdowns?) it says that on the website but I just need to make sure lol!!
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Quote Originally Posted by TopRod View Post
    there was a thread last night and 3 people with these kits where mentioning flikering, something to do with the cancellers not working...
    But i think they sent new ones out for free
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    This subject has been thrashed out more times than I care to remember but this explains where you stand http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    Mine wentstraight in and 3 weeks later are still spot on...i did take my car back to the mot place i use after fitting,because i also 'fixed' the adjustment lever...re-adjusted foc with no questions or statements bout the intensity etc
    Liverpool, UK
    Quote Originally Posted by leemarksmith View Post
    So that is just a case of faulty parts? Is the 35w kit good enough or would it be worth getting the 50w kit?
    Quote Originally Posted by gtr1000 View Post
    I've read that a few times before, know that they would not be leagal but as long as the lights are not going to glare anyone and I can actually see at night I'm not bothered.
  1. HIDs-direct
    By KyleSxi in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 16:13
  2. Hids direct
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2012, 12:41
  3. Well done Hids-Direct
    By themarbleman in forum Styling
    Last Post: 4th April 2011, 19:58
  4. HIDs Direct.Are they the best?.
    By felixx in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2011, 16:58
  5. Quick question about HIDs / Xenon bulbs
    By hutch85 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2009, 21:03
