Thread: engine stutter
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    Default engine stutter
    hi guys . driving back from work tonight dual carraige way @50-60 mph in 5th had to ease over for traffic then pick up again then car started to stutter and misfire rev counter seamed to be fluctuating slightly with foot steady kept doing it all the time no lights came on but eased off a bit then it stopped doing it and was ok for rest of the way home already had injector plugs,manifold,egr,flywheel,throttle body any one any ideas starting to p*** me off now always seems to be about the same time of driving from cold
    Regular Member barkzz's Avatar
    Mine did this in blackbpool a few weeks ago.
    Just for fun, start it up when cold, then put both your front demister, and rear demister on at the same time.
    This seemed to slightly re-produce the misfire/knock for me.
    When it did it in blackpool however it was a pig, and after a quick rev, woudlnt settle back down to normal idle. Only ever done it once, and never came back that bad since.
    durham
    update on this problem never does it when cold only when warm more so on light throttle and under load feels like an injector going down but which one is the question at 200 quid each could be a dear guess .spoke to someone at vauxhall technical today they said to fit a blanking gasket between egr and manifold the fiat one sounds a good idea got to be worth a try . give me back the zafira anyday much better motor.
    Nov 2009
    Derby
    Paul'
    I had a brand new 1.9ctdi Zafira doing the same. After much messing about with dealer i was told by vauxhall, "It's a design feature, not a fault". Needless to say the car was gone within weeks. I think it's to do with the DPF cleaning itself at the same time as the EGR operates, but Vx don't seem to be able to cure it. Went back to Petrol in a Vectra. Costs more but more reliable!!( So Far))
    Cheers M8
    Pete
    durham
    thanks pete there seems to be alot of other people with similar problems i think you right a petrol is the way forward
  1. Engine stutter at 70mph.
    By Dobs in forum Engine & Drivetrain
    Last Post: 3rd December 2011, 09:56
  2. DTI Engine Stutter
    By keithtinman in forum Engine & Drivetrain
    Last Post: 29th July 2011, 17:11
  3. SRI 150 CDTI engine stutter
    By sri150 in forum Engine & Drivetrain
    Last Post: 12th July 2010, 20:59
  4. Slight engine stutter
    By frazejax in forum Engine & Drivetrain
    Last Post: 25th August 2008, 17:07
  5. 4,000 rpm engine stutter
    By djhepburn in forum Engine & Drivetrain
    Last Post: 28th February 2008, 21:48
