Thread: wierd problem
    mansfield
    Default wierd problem
    Hi guys, lately the car has been having a few problems.
    1st of all i tried to plug the laptop into the car and use the Op com program to read the codes, but as soon as i put the program on it says cannot read the ecu, however it reads all the other cars i have tried bar mine.
    even tried a different op com program from someone else but it just will not read the blooming car.
    the car will drive as normal for so long and then all of a sudden it will just not respond with the accelerator, but sometimes if i dip the clutch and then release it again then it will work again,
    other times it happens and the car completely dies and i have to restart the engine again.
    any ideas on this or has anyone else had this happen?
    The car is a 1.9 cdti (150) vectra 04 plate.
    Steve
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    More CDTI 150 problems!
    Have you tried having a pay with the Diag port, just wiggle it about, it may just have a loose connection??
    Mine reads that message when I forget to put the ignition on!
    mansfield
    tried all the wiggling, its since i put the latest update on for the opcom it stopped working, going to look into reverting back to the previous version i think.
    mansfield
    nobody any ideas?
  1. Some Wierd Stuff
    By Tadpole in forum The 'Off Topic' room
    Last Post: 8th August 2009, 22:10
  2. Wierd Problem with Key / CL
    By shatz in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2008, 18:45
  3. Wierd Climate control problem
    By David2452 in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2008, 17:06
  4. Its a wierd one but need help!
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 21:29
  5. Wierd Startup Problem
    By Cheeky_B in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2005, 10:12
