Results 1 to 10 of 22
Thread: 10K Boost Diesel Decoke-I want to hear from you IF you've used it!
    Birmingham
    Default 10K Boost Diesel Decoke-I want to hear from you IF you've used it!
    Hey folks,
    Just been recommended this stuff by another user and have just ordered a can so am praying this will work for me.
    Want to hear some of your stories about it IF you have used the stuff?
    I googled the product after hitting the buy now button and some of the stories are that it is very dependant on the type of oil in my car [READ HERE], and can actually burn out the Engine/Turbo.
    My car was last serviced by Vx (a chap I used to know so it went in via the back door) but we cannot confirm what grade of oil was used. Should I be OK with it?
    PRODUCT LINKY
    Please help as I am desperately trying to cure the non-existant power sub 1.8k rpm.
    As always fella's, Thanx!
    Bye bye Vec B
    - Hello Siggy!
    Mar 2007
    Tamworth
    I didn't think injection engines, petrol or diesel, needed decoking as the air/fuel mixture is always optimal.
    Since any carbon deposits would improve your compression ratio by sealing the cylinder bore better and reducing combustion volume your problem may lie elsewhere.
    Rochford
    Hi. G
    It doesn't matter what oil is in the car as its not added to the oil and doesn't come in contact with it as it goes through the air intake.
    Regards
    Stuart
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    What have vx said regarding the ecu update? How much? I personally would go after this first before adding something that may improve performance, do nothing or make things worse.
    I think your problem is either the egr valve or throttle body. Have you had this looked at? this is also known to get sooted up drop performance too.
    Gazza4
    Nottinghamshire
    This doesn't sound all that different from the Wynns EGR3 that I used earlier this year - they both look to be de-sooting sprays that you quirt into the air intake. That definitely made a different to my DTi.
    The EGR3 is designed to clean out the EGR valve - which it does - but it also cleans the soot off of everything else it touches as well.
    Obviously read the instructions, but if you use this stuff the same way as the EGR 3 and you have a DTi, then take the plastic cover off the top of the engine and disconnect the air hose the fastens on to the inlet manifold and spray the stuff into the inlet manfold.
    Just make sure there's nothing loose to get sucked into the engine and beware the hurricane from the disconnected air hose if you have to rev the engine past about 1800-2000 as the turbo will kick in.
    Also if you rev it with the host disconnected, you'll get the spanner light as the boost sensor won't see the boost pressure. It does off as soon as everything is back together with no need to reset.
    If you want to see how clean your EGR is and to check that it opens and closes OK, you can take the top part of the inlet manifold off using the 4 Torx screws on top. It's all alloy though so beware of crossed threads and over-tightening. The EGR valve will open and close when the engine is hot and revved up past about 2000-2500 RPM.
    Birmingham
    Slippery Sam commented on my other thread about an update via OP-COM he had seen, im awaiting a response to that, here's the link Gaz: CLICKY!
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Quote Originally Posted by James24 View Post
    Can you point me in the correct direction please?
    Bye bye Vec B
    - Hello Siggy!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Vaux-Man-G View Post
    What about the throttle body?? I havent a clue where it is so you may need the assistance of a ramp/axle stands.
    Gazza4
    Birmingham
    Quote Originally Posted by Gazza4 View Post
    What about the throttle body?? I havent a clue were it is so you may need the assistance of a ramp/axle stands.
    Gazza4
    Woops, missed that one.
    Come on someone, me in the right diretcion. Cheers Gaz,
    P.S. HAS ANYONE actually had any issues with this-EVER? Please comment!
    Bye bye Vec B
    - Hello Siggy!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Apparently earlier models had control circuit failure but not 100% on that one.
  1. 10k diesel boost help
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2011, 09:30
  2. DTI 2.0 Decoke?
    By Thom in forum Engine & Drivetrain
    Last Post: 10th November 2010, 23:31
  3. 10K Boost Diesel De-coke
    Last Post: 23rd July 2010, 22:56
  4. diesel noob needs advice no boost under 2k
    By mr.c72 in forum Engine & Drivetrain
    Last Post: 7th March 2010, 14:45
decoking cdti diesel
