Can someone tell me how to connect the wiring for the Audi Style LED lights?
I have them connected to the foglights but it will flicker when off, very annoying.
Do I need to get a DRL module?
Wiring diagram will be very helpful.
Please help!
Please help!
the headlight monitoring system will cause the leds to flicker as it doesnt like them you would need to fit a resistor in line to prevent the flickering
Just get an Audi
fit them to a diy switch on the dash wired from the ciggy lighter or something?
ive read here that someone wired them up to the radio
Wire them up to the stereo illumination.
This is not monitored by the canbus system.
They will also light up when you unlock the car, which looks very flash!
i have DRLS on mine and i found a spare fusecavity within the engine bay that becomes active with engine running.
easy to wire in, but i def wish id have thought of wiring it to the info screen backlight.
