Thread: Removing paint question.
    Sep 2009
    Consett County Durham
    Vehicle : 52 Vectra c LS 1.8
    Default Removing paint question.
    Hi,unfortunately my car has been vandalised with emulsion paint,i have managed to remove it easily from the metal body,its the plastic where the window wipers sit which is the problem,what would anybody recommend to remove this.Regards Martin.
    Mileage : 55000
    Has the paint dried? as this will make it more difficult to remove. Have you tried white spirits or paint brush cleaner. As it is not on the metal paintwork these products might be of help. If you do try them, then it might be a good idea to wash the area down with soapy water afterwards to remove the white spirits/paint brush cleaner. Both of these products I would keep off the metal paint work.
    Full Member Big Sig's Avatar
    Maybe a stiff brush with a lot of hot water and soap?
    WGAF#5
    the only problem with the scuttle cover is that its an untreated plastic area - which no doubtedly will absorb all manner of muck/grease paint etc thats thrown at it - best advice would be to remove and attempt to clean - if no good then a trip to the scrappy would be the cheapest option
    Just get another, very easy to change
    Feb 2007
    North west
    I would take it off the car before I tried to clean it. Do you know who did it and why ? The worry is they could strike again. A woman scorned ?
    Full Member lizard's Avatar
    Oct 2006
    southampton
    11 Post(s)
    WOT IS WRONG WITH PEOPLE THESE DAYS. BRING BACK HANGING.
    If its only black plastic, you could try nail varnish remover, AVOID PAINTED AREAS, i used it on back windows and rear lights after it came out of bodyshop with overspray on it... Be careful though...
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    if it's only emulsion just soak it over and over, or stick it out in street when it's raining (usually everyday recently) the paint will then go soft, then blast i with a pressure washer. Are you certain its emulsion not masonry paint etc.
    Sep 2009
    Hi,Yes it is definitely emulsion,i was lucky if you can call it lucky that it was done when there was heavy rain all night.I used a steam cleaner when i was at work,but it didnt remove it on the plastic completely although it is faded.Regards Martin.
    Full Member paul.sessions's Avatar
    leighton buzzard
  1. Question about removing paint
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2012, 07:26
  2. question before removing 2.2 direct egr
    By ScottyV6 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 10:03
  3. Removing paint swirls?
    By Andy17899 in forum Detailing and Car Care Discussion
    Last Post: 27th September 2008, 11:56
  4. Swirl removing question
    By mikey68 in forum Detailing and Car Care Discussion
    Last Post: 8th September 2008, 21:32
  5. Question about removing front bumper
    Last Post: 25th June 2007, 09:16
