Thread: OK, Now I'm Confused (Fault Codes)
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    confused OK, Now I'm Confused (Fault Codes)
    Can anyone link me to the definitive source of fault codes for the Vec-C?
    The reason I ask is because Rushy's sticky thread here states one thing, yet Ste's post here states another, which looks like it comes from this list (or one similar).
    The reason I ask is my EML has come on today with the following codes:
    Rushy's list =
    P0170 Fuel Trim Malfunction (Bank 1)
    P1614 SBDS Interactive Codes
    P1616 SBDS Interactive Codes
    Other list =
    P0170 Lean Exhaust C-30
    P1614 Wrong Security Code received Immobiliser C-06
    P1616 Wrong Vehicle ID from Instrument Control Module C-40
    So you can see where the confusion comes in, I have no idea which is correct, heck, they could both mean the same thing just worded differently.
    The car seems to run fine, I had a new flip key a couple of months ago in case that's at all relevant, but the it's no different with the old keys. Any help would be greatly appreciated.
    Trim : GSi
    Mileage : 39k
    Anyone?
    Birmingham
    Come on folks, help the man out, post been on for over a day!!
    Some here too: http://www.vectra-c.com/forum/showthread.php?t=67577
    Bye bye Vec B
    - Hello Siggy!
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    P1614 - Wrong transponder key
    P1616 - CIM (Steering Column Module) Wrong Environment Identifier
    from TIS, cant print a whole due to having to scan each module and check each code against it
    P0100 Mass or Volume Air Flow Sensor Circuit Range/Performance
    P0100 Mass Or Volume Air Flow Circuit Low Input
    P0100 Mass Or Volume Air Flow Circuit High Input
    P0100 Torque Control Interaction Too Long
    P0110 Intake Air Temperature Sensor Circuit Low Input
    P0110 Intake Air Temperature Sensor Circuit High Input
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit High Input
    P0120 Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance Problem
    P0130 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0130 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0130 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1)
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) C-027
    P0135 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Open (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0136 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0136 O2 Sensor Circuit Range/Performance (Bank 1 Sensor 2)
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0150 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0150 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0150 O2 Sensor Circuit Range/Performance (Bank 2 Sensor 1)
    P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Open (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0156 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0156 O2 Sensor Circuit Range/Performance (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit High Voltage (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Low Voltage (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0201 Cylinder 1 Injector Circuit High
    P0201 Cylinder 1 Injector Circuit Open
    P0201 Cylinder 1 Injector Circuit Low
    P0202 Cylinder 2 Injector Circuit High
    P0202 Cylinder 2 Injector Circuit Open
    P0202 Cylinder 2 Injector Circuit Low
    P0203 Cylinder 3 Injector Circuit High
    P0203 Cylinder 3 Injector Circuit Low
    P0203 Cylinder 3 Injector Circuit Open
    P0204 Cylinder 4 Injector Circuit High
    P0204 Cylinder 4 Injector Circuit Open
    P0204 Cylinder 4 Injector Circuit Low
    P0205 Cylinder 5 Injector Circuit Low
    P0205 Cylinder 5 Injector Circuit High
    P0205 Cylinder 5 Injector Circuit Open
    P0206 Cylinder 6 Injector Circuit High
    P0206 Cylinder 6 Injector Circuit Low
    P0206 Cylinder 6 Injector Circuit Open
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Low Input
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit Range/Performance Problem
    P0220 Throttle/Pedal Position Sensor/Switch "B" Circuit High Input
    P0230 Fuel Pump Primary Circuit Low
    P0230 Fuel Pump Primary Circuit High
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0313 Misfire Detected at Low Fuel Level
    P0325 Knock Sensor 1 Circuit Low Input (Bank 1 Or Single Sensor)
    P0325 Knock Sensor 1 Circuit High Input (Bank 1 Or Single Sensor)
    P0330 Knock Sensor 2 Circuit High Input (Bank 2)
    P0330 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0335 Crankshaft Position Sensor "A" Circuit Open
    P0336 Crankshaft Position Sensor "A" Circuit Range/Performance
    P0340 Camshaft Position Sensor Circuit Range/Performance
    P0340 Camshaft Position Sensor Circuit Low Input
    P0340 Camshaft Position Sensor Circuit Open
    P0340 Camshaft Position Sensor Circuit High Input
    P0422 Catalyst System Efficiency Below Threshold (Bank 1)
    P0432 Catalyst System Efficiency Below Threshold (Bank 2)
    P0441 Fuel Tank Ventilation High Flow
    P0441 Fuel Tank Ventilation Solenoid Valve Sticks
    P0443 Fuel Tank Ventilation Valve Voltage High
    P0443 Fuel Tank Ventilation Open Circuit
    P0443 Fuel Tank Ventilation Valve Voltage Low
    P0607 Knock Sensor Circuit Malfunction
    P0615 Starter Relay Circuit Malfunction
    P0615 Starter Relay Circuit Low Voltage
    P0615 Starter Relay Circuit High Voltage
    P0654 Engine Speed Signal Range/Performance
    P0725 Engine Speed Signal Range/Performance
    P1110 Intake Manifold Solenoid Valve 1 Circuit High Voltage
    P1110 Intake Manifold Solenoid Valve 1 Circuit Low Voltage
    P1110 Intake Manifold Solenoid Valve 1 Circuit Open
    P1120 Accelerator Pedal Position Sensor 1 and 2 Signal Incorrect Ratio
    P1120 Accelerator Pedal Position Sensor 1 Low Input
    P1120 Accelerator Pedal Position Sensor 1 High Input
    P1120 Accelerator Pedal Position Sensor 1 Incorrect Signal
    P1120 Accelerator Pedal Position Sensor Malfunction
    P1122 Accelerator Pedal Position Sensor 2 Low Input
    P1122 Accelerator Pedal Position Sensor 2 High Input
    P1230 System Voltage Malfunction
    P1500 Throttle Control Motor Malfunction
    P1523 Throttle Control Malfunction
    P1526 Throttle Control Malfunction
    P1813 Invalid Signal from TCM (Transmission Control Module) AF 23-5/33-5 Electronic 5-Speed Automatic Transmission
    P1814 Invalid Signal from ECC (Electronic Climate Control) Electronic Climate Control ECC
    P1811 Torque Signal Malfunction (CAN)
    P1835 Kickdown Switch Circuit Malfunction
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    Thats from the 3.2 Engine module.
    If anyone has microsoft office Excel and wants to start collating this list I will add each module over the next few weeks and then you should be able to 'sort' the list in excel to get the number sequencing right. If theres no interest I wont do it.
    Melbourne, Australia
    ISO 15031-6 is an international standard for diagnostic codes (not GM-specific). It's not freely available, but there's an interesting link amongst some Chinese text here:
    http://www.autoelectric.cn/discuz/viewthread.php?tid=7
    Trim : GSi
    Mileage : 39k
    Thanks fellas. So, it looks like a trip to the dealers is in order. The odd thing is, the car starts & runs fine.
    Trim : GSi
    Mileage : 39k
    A quick thought, I wonder if 1614 & 1616 could have anything to do with the fact I disconnected the alarm siren? It has been disconnected for over a year though, so I don't know why it would be just throwing up errors now, apart from the usual "Safeguard Check" that it does all the time.
    Just hoping for a simple/cheap fix I guess.
  1. fault codes
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 18:41
  2. brake light fault (confused)
    By frigosolver in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 15:34
  3. fault codes
    By Rennie in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2010, 21:12
  4. Confused with fault codes
    By devrim in forum Engine & Drivetrain
    Last Post: 7th July 2008, 14:00
vectra 3.2 p0330
p0330 vectra 3.2
https:www.vectra-c.comforumshowthread.php97449-OK-Now-I-m-Confused-(Fault-Codes)
vectra c knock sensor bank 2
02 sensor high voltage bank 1 sensor 2 on vectra c
