Thread: Idle on 2.2
    Regular Member Cossy's Avatar
    East Yorkshire
    Default Idle on 2.2
    I've got a 2.2 16v on a 52 plate. Just recently the idle has started to drop or over rev, Nothing major but still abit worrying.... after reving or driving and then stopping it might drop to 500rpm and then go back to the normal 900rpm tickover. Equally sometimes after stopping it sometimes reves upto 1500rpm before dropping back down to tickover.
    Any ideas? Is there an idol control valve anywhere or sometime i need to clean or replace, any advice would be helpful
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    is this all the time or when your engines cold...
    Mine cant decide weather it wants to tick over from 600 or 800 when 1st start. but couple miles later its fine when warm...
    East Yorkshire
    its all the time really, doesn't make a difference if ive just started it or ive done a 500 mile round trip somewhere.
    East Yorkshire
    Anybody got any ideas as i cant seem to get to the bottom of it.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There's no idle control valve mate on the 2.2 TB, the gap around the butterfly does most of the work if this gets dirty it blocks off the little amount of air needed to give the correct tick over. To start off give the TB a good clean, inside and out, then check for and leaks on and vac lines. THIS LINK might help mate, its another 2.2 vec c having the same problem over on the 2.2 forum. HTH
    East Yorkshire
    as always rushy you are the 2.2 expert, i will give that ago and see if it solves the problem
  1. dti idle
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 28th October 2012, 01:32
  2. idle idle? haunted car lol!!
    By 1smokinace in forum Engine & Drivetrain
    Last Post: 27th May 2009, 21:28
  3. Idle on a 2.2 Sri
    By chilljohn in forum Engine & Drivetrain
    Last Post: 6th February 2009, 22:57
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. 3.2 gsi at idle
    By STEVE S in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2007, 19:26
