Results 1 to 10 of 27
Thread: No Cigarette Lighter
    Dundee
    Default No Cigarette Lighter
    I have a Vectra energy 1.8 which does not have a cigarette lighter fitted. After looking at some threads i have discovered that there are some wires under the gator of the gear lever which i have found. Can anyone tell me if these are the right wires and which block i connect to(see Pic).
    How the car is now.
    Lastly is it just a case of fitting it in the slot where the wires are coming out and drilling the blank plate or can i buy a plate with the hole pre drilled.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Its an option mate. Its called the smokers pack. The large black plug is for the actual 12v feed for the ciggy lighter and the little white one is for the ash tray light. HTH
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Hmm, I wouldn't mind getting shut of mine for one of those blanking plates.....
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Dundee
    Smile
    Could do a swap. Just need an outlet to plug my sat nav into.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    Have you got the rear socket by the rear vents?
    Dundee
    No don't have any power outlets
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    unless DAN wants to swap of course, i'd suggest leaving it blanked. get any cheap lighter that the vaux power cables will plug into, and then leave it lose underneath...
    Can run the wire for the sat nav behind the dash then and make it look a little neater IMO...
    I had a slim ps2, TV and mobile charger running off a 3 way split cig lighter adaptor hidden underneath the ashtray, was easier then hardwiring and you couldn't spot it...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Lol the things that were optional on some of the vecs are unbelievable
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    "would you like a steering wheel with that sir"
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. Cigarette Lighter
    By BJRM7241 in forum Electrical & ICE (including SatNav)
    Last Post: 15th March 2009, 16:28
  3. cigarette lighter
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2008, 21:28
  4. cigarette lighter
    By PYNE999 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 11:28
vauxhall vectra no cigarette lighter
vectra without cigarette lighter
vectra c no power to cigarette
vectra cigarette lighter
vectra c cigarette lighter
vectra c cigarette lighter removal
