Thread: will vxr springs fit my 2003 2.0dti
    london
    Default will vxr springs fit my 2003 2.0dti
    as the title says-
    I was looking to uprate my springs and have my eye on a set ot vxr springs as they are cheap and i'm not looking to lower me beast much- but will they fit??? the seller has confirmed the are the suited for the weight but I'm wondering if the fittings are the same??
    thanks in advance gents
    Cambridgeshire
    The problem is that the VXR springs are designed to hold a 2.8 ltr V6 petrol engine and you'll be asking it to hold a 2.0 ltr DTI engine. Best asking someone on here with a VXR to check their door pillar for the front axle weights and compare them to yours just to be safe. Otherwise it could sit too high at the front or too low
    If it comes that these weights are near as dam the same then there is no reason why they wouldn't fit your motor mate
    West
    Yes they will fit, & as above you need to make sure the axle weights are the same or very near
    london
    thanks guys- I believe both cars fall into the 1001kg+ front axle category so I may be onto a winner. also believe all rear axles apart from the estates share the same springs anyway- is ths correct too??
    ta in advance- again :-)
    Cambridgeshire
    Yes mate, usually about 980kg so I believe...
    Pics before and after mate
    london
    according to another thread the vxr axle weights are
    1) 1095
    2)985
    mine are
    1)1060
    2)980
    so do you guys who know molre than i think or believe the vxr springs would be suited to my dti??
    I'm guessing 5kg difference on the rear isn't gonna make the slightest odds as s bag of shopping can weigh that- and it seems equally plausible that the 35kg heavier on the front would only mean both cars fall into the 1060+ spring category with the 2.2 dti and the 1.9cdti- and that the 3.0cdti and the v6 petrol going into the 1101kg+ spring category, leaving the 1.6, 1.8, 2.2 petrols in the 995 category???
    been reading a lot today :-)
    does my thinking make sense or have i been here too long?? 8-D
    West
    Going by those axle weights i'd say they will be fine
    london
    thanks dh.
    shall try to get em bought asap so i've got em ready when i can afford the b4 in a few weeks.
    I'm assuming the vxr are the same drop as eibachs and that b4s are gonna be ok.
    anyone knowe different?
    ta
  1. New Member [2003 Elite 2.0Dti]
    By spikeyboi33 in forum Introduce yourself.
    Last Post: 28th January 2013, 21:24
  2. Mis firing 2003 vectra 2.0dti
    By dezzypoole in forum Engine & Drivetrain
    Last Post: 11th February 2011, 00:29
  3. 2003 2.0dti 8v fails to Start
    By Neil.b in forum Engine & Drivetrain
    Last Post: 6th January 2009, 21:02
  4. what speakers for a 2003 2.0dti LS???
    By stubopvectra in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2008, 15:28
  5. VX 2003 2.0DTi Juddering
    By cp123 in forum Engine & Drivetrain
    Last Post: 13th June 2006, 23:48
