Thread: Swirl valve Cleaner ?
    Sep 2009
    Glasgow
    Default Swirl valve Cleaner ?
    Is it possible to clean the crud around the swirl valves using carb cleaner or some other product, not much mentioned about this. Any potential problems that would arise from doing this.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Are you referring to the actual swirl flaps or the pegs/rod on the top of the manifold as there shouldnt be any rubbish there.
    If you are talking about the actual internals of the manifold I wouldnt recommend it - driving slightly hard for a few miles once a week should keep them clean.
    Gazza4
    Leicester
    Running permanently on V-Power Diesel or BP Ultimate diesel will clean everything up and keep it clean.
    But my advice, if it is not playing up, don't take it to bits to clean it. Let the decent fuel do it's stuff over a period of time.
    Probably why i have never had a fault.
    Sep 2009
    Glasgow
    just gunk round about swirl valves, like oil deposit cant see any leaks think some oil might have been spilled last service. dont want it to cause problems with valves.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    hope its not oil'y crud coming from the swirls ??, have you had the new manifold fitted or still on the old type ??.
    Sep 2009
    Glasgow
    not sure, have a 3 year waranty anyhow how do i tell if I have the new one, mates swirls are the same and so is his brothers it just looks dirty dont want it building up and cause problems later.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    here are the two types, there have been modifications made to the swirls
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    soz forgot the other 1.
    Regular Member barkzz's Avatar
    Ive got cruddy oil around the top of my swirls, but am well aware this will be a manifold issue, and most likely require replacement.
    It's only just come back from the stealers after yet another warranty job, so im going to hang fire for two weeks, before booking back in again
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. Liqui Moly Diesel Throttle Valve Cleaner - Any Good???
    By hotrod09 in forum Engine & Drivetrain
    Last Post: 10th October 2010, 15:48
  4. carb cleaner swirl valves ?
    Last Post: 23rd February 2010, 22:37
  5. Swirl Valve Again!!
    By KC in forum Vectra C / Signum Car Chat
    Last Post: 27th December 2008, 23:37
