Results 1 to 10 of 14
Thread: 1.9cdti water temp
    SAUCHIE
    Default 1.9cdti water temp
    Hi. Has anyone else had this problem. I had a 1.8 petrol vectra and the temp went dodgy and I replaced the thermostat myself which cured the problem. The 1.8 petrol engine was at operating temp in a few miles. I have now recently purchased an SRI 1.9CDTI but it takes about 20 mins running time before the temp gauge moves and when it does move the minute I put the heater on it pulls the temp right back down the bottom of the temp gauge and heater is poor. The OBC says that I am getting 37 MPG. Is the running temp and MPG for the 1.9 CDTI normal.
    Full Member Big Sig's Avatar
    No its not normal, diesels do take a while to heat up due to the nature of the engine construction. I'd be looking at the thermostat too
    SAUCHIE
    Thanks. My CDTI is an 09 58 plate model and am not happy that the thermostat is needing changed with only 13k miles on it. Can you tell me on average how long they take to heat up and what kind of mpg around the doors I should get. I was getting around 36mpg with the 1.8 petrol and I thought the diesel would be much better. cheers
    Regular Member benny's Avatar
    Feb 2006
    dudley
    hello mate does your car have climate control fitted? .
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    mines is like that, heats up to about 80, but should be 85-90 - and i would say thermostat.
    Feb 2006
    dudley
    cars fitted with climate control have the air con switched on all the time ..so the cooling fans run all the time and over cool the engine *(fans run at a slow speed).....in the options list on the display there is a option to switch the aircon off .............other than that they do suffer with poor thermo stats ......but 13k is a little low for one to fail.....
    fife
    mine is a06 plate 19tdi club ive seen my temp gauge vary between 80 and 85 and I have air con
    Regular Member P3tchy's Avatar
    Milton Keynes
    I run mine with the ac off and get 47mpg with a lead foot. But my temp guage has never gone above 80.
    Feb 2006
    dudley
    Quote Originally Posted by xc600 View Post
    air con has a switch to turn on and off .....climate dont it runs all the time ...
    SAUCHIE
    Thanks all. My car doesn't have climate control. It has a seperate switch for the aircon cold air. I had the car out yesterday in the cold and after about 20mins running on motorway the temp moved to around 70 but the min I put heater on the temp dropped right back down to bottom of gauge and wouldn't move till I switched heater of and really started booting car. It is going into VX on wednesday to get the "heater" checked but I have told them that its the thermostat and not the heater as when it does heat up a bit the heater gets better. Thanks
  1. water temp dial
    By IRMSCHER ALBA in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2012, 01:33
  2. Water temp gauge
    By obews in forum Engine & Drivetrain
    Last Post: 6th August 2012, 19:07
  3. water temp gauge
    By vectra.sri in forum Engine & Drivetrain
    Last Post: 26th August 2011, 00:18
  4. water coolant temp sensor....
    By bertiecbx550 in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2010, 13:54
  5. Bizarre water temp fault 2.0T
    By Mark 626GT in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2010, 12:35
vauxhall signum 1.9cdti watter temperature
