Thread: 1.8l Petrol - K&N Filter or Kit?
    Bedford
    Default 1.8l Petrol - K&N Filter or Kit?
    I have real issues with the pull away on my 1.8L (2006) Vectra. It almost konks out when I hit the biting point on the clutch. Is this a common problem with these?
    I was thinking of maybe replacing the air filter (just because I have done it once before on a prev car and have zero mechanical experience). Was looking at the K&N filter but then saw they do a full 'kit'. What would people recommend? Or should I be spending my money elsewhere?
    Many thanks in advance....
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Quote Originally Posted by mpgough View Post
    I would spend your money getting the car looked at instead. Why change the air box/filter if the clutch is on its way out???
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    How long have you had the car? I'd say the problems are likely to be clutch, or clutch control. Maybe you just need to get used to the car. They're not very powerful beasts the 1.8 L's so not that difficult to stall.
    Regular Member ahaz123's Avatar
    Oct 2009
    N. Ireland
    i have the same car mate. 07 1.8vvt sri and i can say ive never had that problem. as the others have said it may be the clutch. my last car did that and very soon hey presto the clutch went!! i have the k&n panel filter aswell and i can say it does make a difference. not performance wise.. but it gets rid of those annoying mid range flat spots!
    Mar 2007
    Tamworth
    Vauxhall engines, and 1.8 in particular, don't like induction kits as they're sucking hot air from the engine compartment rather than cold air as the standard fit.
    Induction kits can be made to work by installing them in a box and feeding cold air from in front of the rad but there's no advantage doing all that work compared to juist replacing the filter.
    Personally I'd keep an OE filter but changed more often.
    Bedford
    Default Ummmm.....
    I would agree its the clucth but it has done it since I got it (in 2007). And I have put 40k on it since.
    Bedford
    Quote Originally Posted by ahaz123 View Post
    ....sorry didnt mention its not a vvt sri - just a bog standard 1.8l.
    Engine : Z18XE
    Quote Originally Posted by Ruperts Trooper View Post
    What about an uprated i.e. K&N panel jobby in there?
    Oct 2007
    south wales
    Still sounds like the clutch is on its way out, why not get it checked out?
    Changing the filter to one of the ones that you hae to oil could in my opinion be risky, I would stick with the standard one , and just change it more often.
    The air intake can be changed for one of the longer intakes off the larger engines.
    Regular Member Gray16v's Avatar
    Nov 2009
    Stoke on trent
    Got a pipercross panel filter in mine, its really good
  1. Petrol Fuel Filter
    By wafoo in forum Engine & Drivetrain
    Last Post: 9th August 2012, 19:36
  2. Fuel Filter - Petrol
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 11:21
  3. Fuel filter - petrol
    Last Post: 6th December 2010, 14:31
  4. 2.2 petrol oil filter packaging
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2006, 19:20
vectra c 1.8 k&n panel filter
