Thread: Broken car....Not atteming starting..throttle postion sensor?
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default Broken car....Not atteming starting..throttle postion sensor?
    On my way to go shopping....Tration control light came on.
    Revs stuck to 1500rpm and got no throttle response at all!!
    Turned engine off (Big mistake) and would not attemt to start again.
    2hours later just before the RAC arrived it started but still no throttle responce.
    The Rac man turned the engine off and wouldnt start again.
    He plugged in diagnostics machine and it came up with the following fault codes
    P1120 - throttle position sensor
    P1122 - throttle position sensor
    P0621
    P1614
    P0380
    P1616
    Something he did reset the throttle responce sensor and then he cleared all the other fault codes.
    Went to start it. Nothing
    He then bypassed the canbus i believe and ran a wire straight from the battery to the starter motor and it fired straight up!
    Drove round the corner on came the TC light came back with no throttle response. I limped it home.
    Now its sat on the drive.
    Wouldnt start so ive dissconnected the battery for now.
    Lots of money at vauxhalls yes?
    Jul 2009
    Tamworth
    Anybody???
    Im skint i cant afford all these modern shi.te electrics!!
    Glasgow
    Might be lucky could just be a new pedal required with any luck.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    P0380 - Glow Plug/Heater Circuit "A" Malfunction
    P0621 - Generator L-Terminal Circuit
    P1120 - Throttle Position (TP) Sensor 1 Circuit
    P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
    P1614 - Wrong Security Code received Immobiliser
    P1616 - Wrong Vehicle ID from Instrument Control Module
    Do you get the padlock symbol on the dash?
    The throttle position sensor (TPS) errors could be either a dislodged plug or a defective sensor. I don't know if you can buy the sensor separately from the accelerator pedal. Firstly I would remove the sensor and check the resistances with a multimeter as you move it between the limits of it's travel.
    Some have 2 outputs - one goes higher as the other reduces resistance and there may also be an idle validation switch inside it too. A stuck idle is indicative of a failed TPS in some way.
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    this is a long shot.
    try your spare key.
    Jul 2009
    Tamworth
    The key and immobiliser fault codes are me. I took the transponder out the key to see if it came up with the same light on dash thinking maybe it was an immobiliser fault. Thats when i got a padlocked car.
    Went out this morning and started it up using a long piece of wire with the battery and starter motor.
    Up she fired and I had all throttle response back so i went to vauxhalls. Left it with them.
    As i walked into reception I thought id turn around and try starting it again just incase its fine and I look like a prat.
    Haha....it was fine and started.
    Typicall.
    Its having a major service while its there.....£208!!! And then whatevers wrong with it ontop as theres bound to be something!!
    Pilsen
    Hi, at first sorry for my english... So, i've got vectra c Z18XE and this night on my way home blinked on me car with key and vectra fell into emergency mode (it was for third time, first time 10 days ago). Engine rpm were beetwen 1300 - 1500, max speed 20km/h.
    Diagnostics says
    P1500 - Throttle Control Motor Malfunction
    (52) - Not present
    P1550 - Electronic Throttle Control Power Management
    (03) - Not present
    Does anybody know, where is a problem? I read that it could be in ECU. I cleaned up throttle control, but still the same problem.
    Jul 2009
    Tamworth
    Ive work out how to fix this problem if anybody has it again!
    Turn the ignition off but leave the key in,unplug the wire to the commonrail.....wait few seconds and plug back in!
    Away you go!
  1. 2.0 dti throttle postion sensor problem
    By frankiebdv in forum Engine & Drivetrain
    Last Post: 25th March 2012, 14:15
  2. 2.2 dti starting ok but wont take the throttle straight away
    By peadar in forum Engine & Drivetrain
    Last Post: 16th December 2011, 00:26
  3. Throttle Position Sensor
    By RichyA in forum Vectra C / Signum Car Chat
    Last Post: 23rd September 2010, 15:12
  4. throttle sensor wires
    By peadar in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2009, 10:36
  5. Throttle sensor
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2007, 19:10
car stuck at 1500rpm vectra
immobiliserfault vectrac 2.0 dti
vauxhall vectra c p1614 www.vectra-c.com
p1614 vauxhall fault code
