Thread: CDC 2006 reading Disc error
    Derby
    Default CDC 2006 reading Disc error
    Afternoon,
    Havin a little trouble with my stereo, the one with the 4cd changer mounted in.
    Started with a fault where the cd cartridge wouldnt click into place, so stripped the sterio out, and found a dodgy metal tab for the switch that detects the cartridge.
    Bent it out, and now all is ok.
    Loaded cds in, all genuine off the shelf, and tried all the cds, RDM play etc etc, and all was ok.
    However, i went to swap the cds over, unit ejected fine, loaded new cds in fine, did the initial check fine, then asked what cd to play. No matter what cd i choose, it comes up with CD ERROR, and skips to the next cd, and does the same. I can hear the unit spinning the cd up, and the CD rotates in the changer fine, but it just wont play a disc.
    Everything else works fine
    Anyone have any ideas? its doin ma head in!!!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Got the same stereo and as far as im concerned - it is the most irritating thing about my car. Mines occasionally decides there is a disc error.
    Gazza4
    Derby
    Mines all the time now. Used a pencil to trick the player into thinkin the cartridge is in, it moves the arm up and down, in and out, the cd spindle turns the disc.
    If i put no cds in, or put them in upside down, it reads NO CD, it regesters the CD when i insert them, but when i try and play, it just shows error. Tried at least 20 cds, and its the same on all. GGRRRRRRRRRRR
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    New head unit then bud - I wouldnt waste any money on this one, although keep the head unit as you will need this for when the battery is disconnected - if the alternator needs replacing etc - to input the security codes etc.
    Gazza4
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Daft question, but have you cleaned the laser??
    Cheap cd lens cleaner may work...especially if it has never been cleaned.
    electronic devices attract a lot of dust and crud over time.
    Other than this, yes VX radios are very weak...the cartridges seem to give no end of grief.
  1. Cd70navi unit disc error !!!
    By Maxim007 in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2011, 13:47
  2. V6 CDTi reading error codes
    By averdigi in forum Engine & Drivetrain
    Last Post: 20th October 2010, 23:54
  3. CD70 'Reading' Satnav disc
    Last Post: 27th September 2010, 19:07
  4. CCR 2006 4 disc Magazine
    By Big Sig in forum Parts for sale
    Last Post: 19th April 2009, 21:56
error cdc vectra
error cdc signum
