Thread: Wrong Travel Assistant..
    Unhappy Wrong Travel Assistant..
    Bought a travel assistant on wednesday then off down to VX for the fitting kit..Yesterday me and Pioneer tried to fit it,did all the "cutting"of the carpet ,fitted the bracket,fed the wiring through back to the boot fusebox,THEN went to fit the TA and its the wrong one .Its for the Signum............................................ ...............................................
    GUTTED, im not havin much luck with mods at the mo...tried gettin hold of the guy who sold it ,as he described it as for the SIGNUM & VECTRA-C..God im so,so stupid, i should have known..
    Well if i get no response from him today, i'll either drive up during the week or sell it on here or Flea-bay.............................................
    Aww no micky..
    he'd have got me too..from what little i know about TA's, i'd have bought it as well, as i thought only the mounts are different..
    if you do list it on here, someone will have your arm off for it..
    Jan 2006
    Dalriada
    Thats a sore one Micky hope you manage to get all your cash back fella
    Regular Member Ian's Avatar
    York
    I thought the actual TAs are the same too, only the L shaped mounting stand is differeent? Micky - speak to John (CDTi) as I'm sure heres looked into this in detail.
    Regular Member The Doc's Avatar
    'Norf Yorks.
    As above Micky, Travel Assistant itself is the same. It is the mounting bracket that is different. The actual bit that plugs into the floor and goes over the seat.
    Can PM ya my mobile number if you want?
    Still awaiting mine
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    As what Ian and CDTi have said Mickey you only need the mounting frame to suit the Vec-c, the actual travel assistant is the same.
  1. Travel Assistant
    By signum_rob in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2012, 20:28
  2. Travel Assistant
    By ben and ellies dad in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 16:32
