Thread: P1125-0f
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Default P1125-0f
    Hi guys
    had my spanner light come on and give me this code.
    the light went straight off once car was started.
    so cleared fault and it hasn't come back.
    so my question where do i look to see if something is wrong.
    how much could it cost?
    or should i just cross my figures and hope for the best
    P1125 - Throttle Actuator Malfunction
    (0F) - Not present
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Just check if your swirl valve rod is off or not. You have to remove the engine cover and look at the base of the glow plugs:
    Apr 2009
    Bournemouth
    just had a look but i cant see it. i remember there was an old thread where someone ha a 150 but couldn't see it?
    could someone pleas confirm that i have one my engine is a 19DT not the DTH
    05 plate
    thank in advance
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    I've had this problem on my 150 CDTi back and forth for about two months. I cleared the fault then it came back on a few weeks later. The car still drove perfectly though. Last week the light came on and stayed on (car still driving fine). I decided to take of the throttle body to investigate (harder than it should have been thanks to what can only be described as a butcher that works at vauxhall who's had it off before) it was chocked full of coke. Thick black and very restrictive. I cleaned it all up and lubed it off. Adjusted the pins on the plug too. I refitted and to my pleasure no faults!! That was about a week and 300 miles ago so fingers crossed. I'd start there before throwing parts at it!
    Apr 2009
    Bournemouth
    bump
    Wales, UK
    Cant help really but had to double take at the thread title !!! lol
  1. code p1125 (61)
    By the-wizard in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:33
  2. question on code p1125
    By collyb in forum Engine & Drivetrain
    Last Post: 24th April 2011, 15:34
  3. Code p1125
    Last Post: 23rd April 2011, 23:46
  4. fault code P1125 ??
    By cov in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 12:10
  5. Oh Dear, How bad is a P1125 Fault Code
    By markm in forum Engine & Drivetrain
    Last Post: 11th September 2010, 23:07
p1125-0f
