Results 1 to 10 of 11
Thread: Tyres for 18's
    Regular Member bigbnlr's Avatar
    Belfast
    Default Tyres for 18's
    Hi guy,
    Can someone please tell me what tyres I should have on a Vectra with 18's, My wheels came from an Astra and have 225 35 18 which are spine shattering tbh. I would like to go as big as possible, but I also plan on lowering it 30 or 40 mm.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    225/40/18 iirc
    225/45/18 official size, but rare and very expensive, 225/40 alternatve, 235/40 also alternative and fitted to VXR with standard 18's...
    Belfast
    225/40/18 iirc
    Quote Originally Posted by Penfold101 View Post
    Thanks guys, would there be much difference in the ride comfort between 45 and 40, took the wheels off the car because of these 35 xl tyres tbh
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Should make a bit of a difference bud, there will be 5% more rubber there
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    I recently fitted new 18" boots to mine.
    See my THREAD here.
    Hope this helps,
    Paul.
    Snowman, you got your ears on?
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    I'm running on 225/45/18 95y Toyo T1r & the ride is firm but fine, not too bad at all for low profile tyres
    Try here for tyres Click me
    Leicester
    On the 11 Spokes, as they are only a 7.5" rim, 225 45 18" tyres are the correct and best fit, I have just bought a set of these, Avon ZZ3 and they were £323 inc VAT delivered.
    As Penfold101 has said, 235 40 18" tyres are suitable as they are VXR standard fitment but just about right for a 7.5" rim but an 8" rim is better for 235 tyres.
    If you have the Astra G fitment wheel with 225 35 18" tyres, the wheels are the ET45 fitment, so to get things 100% factory, a 4mm spacer would be advised to bring them down to ET41.
    Belfast
    Cheers guys looks like 45's then, thanks for all the help. Maverick would the 4mm make much difference?
    Leicester
    Quote Originally Posted by bigbnlr View Post
    Depends on how fussy you are. With wheel offset, if your car supposed to run ET41 and you drop to ET37, it's not much of an issue.
    But when you go the other way it can upset the balance of the car. The worse thing is, is that I imagine your wheels (If they are ET45) sit quite inboard on the car. 4mm, or 5mm spacers will give the car the correct stance with the slightly wider track.
  1. 18's
    By barneytravolta in forum Styling
    Last Post: 28th July 2012, 06:14
  2. what tyres for 18's?
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2008, 14:57
  3. Rochford Tyres AP 10 18's?
    By aaruck in forum Styling
    Last Post: 26th September 2007, 10:54
  4. irmscher stila 18's alloys and tyres
    By j1 wyx in forum Parts for sale
    Last Post: 7th June 2007, 20:04
  5. Vauxhall 18's With Tyres And One Spare!!!
    By Mark The Cabby in forum Parts for sale
    Last Post: 22nd June 2006, 19:16
