Thread: ARB Bushes
    Regular Member Danialj32's Avatar
    Sep 2009
    Warrington
    Default ARB Bushes
    Had an attempt at replacing them today, failed miserably, how2 says remove drop links, wasn't entirely sure what they was, pics of the car in the how2 doesn't really relate to my car, and I didn't want to start removing things I shouldn't. The things I suspected were drop links, I didn't have a 18mm spanner for anyway! Any tips? Car is a 2.2 LS 52 plate, cheers.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    front your doing? if so the droplink comes off the arb bar done mine a while back and i think i had to jack the hub up by the droplink for it to just pop off the bottom
    once unbolted, its a dead easy job i followed the how2 and i found it spot on
    Sep 2009
    Warrington
    Sorry, yeah front bushes!
    Oct 2009
    Sandwell
    i had a crunching noise on mine so i took mine off to have a good look at it but it is a easy job to do take your time with it took me a good 3 hours to do it at first (was my first time) lol, if you wasnt to far away i would of done em for ya mate
    folow this for the droplink just undo the bottom one
    http://www.vectra-c.com/forum/showthread.php?t=46475
    Sep 2009
    Warrington
    Yeah, that's what I have, when going over speed bumps, someone said it could be my bushes, I just don't know what i'm looking for though, and wouldn't like to start tampering with things I shouldn't!
    Oct 2009
    Sandwell
    Quote Originally Posted by Danialj32 View Post
    mine turned out to be the bushes, once i replaced them no more crunch its dead easy mate just unbolt the bottom of the droplink that connects to the arb bar and follow the arb bar untill you see the bush, this was my first time at doing it and you learn as you go along
    Regular Member Jezzy's Avatar
    S.E
    The drop link is the long, thin vertical rod, the lower end of which is connected to the anti-roll bar, the top end is connected to the shock absorber-strut. You need to undo the lower end of it just so that you can move the anti-roll bar around a bit.
    Sep 2009
    Warrington
    Right so I don't need to undo where it connects to the shock? This was where I was looking today! Am I going to need to get underneath the car, or will I be able to do this from the side, jacked up on the drive you see, always the fear of it dropping!
    S.E
    No need to get under the car, although always best to use axle stands anyway - even if you're not under the car, you don't want it to fall on it's belly.
    Sep 2009
    Warrington
    I see, shall have another look tomorrow. Don't have any axle stands, just gonna have to keep it jacked I think, shall look into buying some becase I can see them coming handy in the very near future!
  1. A.R.B Bushes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 16th April 2011, 21:39
  2. arb bushes
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 09:51
  3. ARB bushes
    By Marcosuk in forum Vectra C / Signum Car Chat
    Last Post: 19th November 2010, 00:29
  4. arb bushes
    By deeks in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 14:54
  5. Replies: 5
    Last Post: 21st March 2010, 12:34
