Yooooooooooooooooo guys!!!
I do what Nikroc said me yesterday, this morning, i was disconnectef my battery 10mn, an reconnect, the regulator works!!!!!!!!!!!!!!!!
Thanks to all
Thanks to all
does that mean op-com CAN active cruise control?
Yes, you must first activate the crusie controle, go to the motor Ecu, select programming, and select the regulator like "present", valide it, after, go to the CIM ecu, and select the regulator like "present" with the "variant programming" and the code car, valide it, and after, goes to the instrument ecu, select the regulator like "present", save it, and goes out of the program.
Disconnect the battery 10mn, reconnect it, and the regulator is active
This forum will not/does not support any form of pirated/dodgy software or advice which can/could cause 'harm' to the community.
Not sure what your smoking but its not big and its not clever
I didnt say you did say anything bad,this was a polite warning as you were going on about OP-COM and going on about variant coding,i must say your a braver man than me as i wouldnt use that to activate anything on my car its cheap for a reason.
But fair play is it working ok now ?
Irmscher Insignia CDTI 130
Nothing like being definite in your comments!!
The guy has got a problem! Try and help him! Don't get on a high horse and give 'snooty' comments!
It is probably just me. I am still coming to terms with the difference between a forum and a private manufacturers club.
sandbar
PS. Does pirated always = dodgy? Is there no non-pirated software that might cause a problem?
Last edited by sandbar; 13th December 2009 at 15:27. Reason: To tone the post down a bit!!!
