Originally Posted by
jmc
Remove The Rubber Gaiter From Around The Indicator Stalk(on Mine This Was On The Left Hand Side,apparently They Can Be On The Right Aswell.although Never Heard Or Seen This).using A Small Allan Key Or Cocktail Stick,push In The Clip On The Underside Of The Stalk.this Should Release The Stalk With A Gentle Pull.push Your New Stalk Into Place And Refit The Rubber Gaiter On To The Ssteering Column Cover.
stage Two
Pull Up The Cover Underneath The Handbrake To Reveal The Management Plug.with The Ignition Off,plug In Tech 2 And Turn On.
Go To Engine Ecu____diagnostics____variant Configuration____cruise Control.change This From Not Present To Present And Confirm With Program.
stage Three
Exit Back To The Main Ecu Choices Page And Go Into Body____cim(steering Control Module)_____programming______security Code Required(in Your Drivers Handbook Below Vin)_______cruise Control,change This From Not Present To Present And Confirm With Program.
stage Four
Go Back Again Into Body At The Main Ecu Choices Page____ipc/ecu(instrument Cluster Ecu)____programming____programme Variant Configuration____security Code Required(in Your Drivers Manual Below Vin)____cruise Control,change This From Not Present To Present And Confirm With Programme.You may need to change the country code which can be found below the ipc/ecu choices section.You will be prompted if this is required.
stage Five
Exit Out To The Main Menu And Turn Off Your Ignition.disconnect The Tech 2 And Refit The Cover(under Handbrake).
From vxronline
