Thread: Can anyone help?
    Full Member VectraMat's Avatar
    Hull
    Default Can anyone help?
    I was driving home tonight after filling the car up for the drive to pickering tomorrow, when i hot a slightly bumpy bit of road. All of a sudden there was a very loud knocking noise coming from the drivers side, somewhere around the rear wheel arch by the sounds of it. Sounds like something has come loose and is knocking against something else.
    From then on, all the way home, the noise was constant even on the fairly smooth roads, and i can even hear it over the stereo.
    Just wondering if you guys have had the same problem and what you think it might be. Took my dad out in it and he could hear it as well.
    Might have to be a trip to the dreaded stealers......actually the one i use in East Hull isnt too bad since i used to work there.
    Any help would be greatly appriciated.
    cheers guys.
    VXR Gone - Now in BMW 320cd M Sport Convertible
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    sounds like you maybe broke a rear spring matt or sommthing to do with the rear suspension
    Hull
    Quote Originally Posted by david-bell
    Dont think it could be that, wasnt a really bumpy road, just like a country road, but no pot holes.
    Had a quick look in the arch when got home and everything seems fine, but then took my dad out in it and noise was still there.
    But thanks anyway david.
    Trim : vxr
    Mileage : 31000
    dont no then matt exhaust heat shield maybe? that happened with my old vec b had a rattle like what your describing every time i went over a bump or uneven road then i discovered it was the exhaust heat shield . but your saying its coming from the drivers side so might not be that but worth a check maybe
    Regular Member Robbieben's Avatar
    Dec 2005
    Polishing a car somewhere
    May be that a rear shocker has failed Matt as they do Bump quite loud when they fail.
    Hull
    Quote Originally Posted by Robbieben
    Cheers for that, ill have that checked out.
    Also thanks for your seggestion david, but as you say the exhaust is on the wrong side but ill check anyway, never know you could be right.
    thanks for the help guys!
    Nicking Ya Dinner.
    Something silly to check, the rear seatbelt, if it hasn't recoiled properly it can thump against the door panel, prolly isn't that, but it will take seconds to check, keep me fingers crossed for you that it is that though, nice cheap fix eh?
    whilst they're looking at the Damper, get them to check the anti-roll bar's tierod link..if that fails it also bangs like a nutter, even on 'smooth' surfaces..
    Hull
    Thanks guys, knew i could rely on you for help.
    ill let you know how i get in at the stealers on monday.
    Hull
    UPDATE - Took the car to the stealers today and the mechanic went out for a drive in it. Came back 10 mins later and had it up on his ramp for 30 mins.
    Service lass came to me and said "Mr Welsh, weve found the problem and its a Broken front suspension spring"
    To which i said, "but it didnt feel any different and it sounded like the noise was coming from the back, but anyway is it covered under warrenty?
    She says "yes they have agreed to pay for it (costs about £80 i think) but its not really drivable in the condition its in"
    so to cut a long story short i asked for a courtasy car, thinking id get a corsa 1.0, but they refused and said its not possible because of my age (18). So had to get my dad to pick me up and take me back again tomorrow, but hopefully it will be fixed.
    Thanks again to everyone for your help.
