Results 1 to 10 of 15
Thread: which oil ??
    Nov 2009
    cornwall
    Default which oil ??
    Hi. how important is it to use fully synthetic oil ?. i have a 2002 2.0 DTi with 150000 miles. would it be ok to use semi synthetic ?
    Nov 2009
    cornwall
    sorry its 115000 miles not 150000
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I've the Vx 5w30 oil in my 2.2DTi. 117k miles.
    Full Member
    Bristol
    If your car is pre facelift before 05 which it will be 2.2 dti. You can use semi no problems. facelift is fully only.
    Mar 2007
    Tamworth
    Have a look at Opie Oils aka oilman - there's loads of information there.
    Go by viscosity, eg 5W-30, standard, eg ACEA-B4, and manufacturers specification if applicable.
    Semi-synthetic isn't semi - that presumes 50:50 - it's part-synthetic which can be anywhere from 1:99 to 99:1.
    Full Member
    Bristol
    Why go into all this s---. Just read what VX say they say in all prefaclift handbooks that you can use semi and in facelift only use full. That was easy was't it.
    Mar 2007
    Tamworth
    Quote Originally Posted by sb1uk View Post
    What viscosity? What ACEA grade?
    Vauxhall will ALWAYS tell you to have ALL work done at a Vauxhall workshop using Vauxhall parts and materials - but few have that sort of money!
    Full Member
    Bristol
    You can buy vx oil on ebay. its very good oil I think its suppied by mobile. I supply mates with a landrover disc and a passat tdi and they both say the engine is quieter using the vx oil. But as long as you use the correct grade that Vx say you have no problem what make or price. Its all up the cost and choice.
    8 Post(s)
    Their website says that the fully synth 5w/30 should be used in all Vec-C's from 2002 onwards
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    Mar 2007
    Tamworth
    It doesn't say "fully synth" or anything else about synthetic oil - it states:-
    2002 onwards - 5W-30 - ACEA A3 / B3 - ECOService
    GM-LL-A-025, GM-LL-B-025 - ECOService Flex
    2006 onwards - 5W-30 - GM-LL-A-025, GM-LL-B-025 - ECOService
