Results 1 to 10 of 11
Thread: Engine noise on idle - V6CDTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Default Engine noise on idle - V6CDTi
    After a cold start it runs great! Quiet as a mouse. But once warmed up there seems to be a clatter of some sort. Pretty sure it isn't the DMF causing this noise even though it is knackered.
    Should I be worried?
    Full Member
    Bristol
    It could be an idler pully .
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Replaced them not so long ago. It made that noise before the service too.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    The noise seems to be better after some sporty driving.
    Full Member
    Bristol
    DMF will only clatter when you let foot off the gas and engine re-coils.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I know, that's why I ruled it out.
    Full Member
    Bristol
    Without have a listen you cant tell. What about tappets they get wider when the engine is warm.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Thought about that too as the engine has 163k miles with original tappets, but why is the engine quieter now that I'm ragging it?
    Full Member
    Bristol
    When you rag it the engine is reving so fast and with othe noises it may seem quieter doing that.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    After some slow driving the noise is now louder?
  1. Knocking noise at idle
    By Boz657 in forum Engine & Drivetrain
    Last Post: 22nd July 2012, 14:46
  2. Occasional engine noise, slight rough idle, poor MPG
    By Snizzers in forum Engine & Drivetrain
    Last Post: 16th June 2010, 10:44
  3. Idle on V6CDTi manual and auto
    By Celes in forum Engine & Drivetrain
    Last Post: 18th August 2009, 12:45
  4. Replies: 4
    Last Post: 31st July 2008, 15:29
  5. idle gear noise? help !!!!
    By Woodsta in forum Engine & Drivetrain
    Last Post: 21st October 2006, 14:43
