Results 1 to 3 of 3
Thread: Cat removal question
    Jun 2009
    Chelmsford
    Question Cat removal question
    Just read in another thread that you can legally remove the cat from a diesel!!
    I am about to have a twin exit setup on the vectra 1.9 cdti SRi, so want to know if this is correct, if so what is the advantage / disadvantage of doing this??
    Full Member Big Sig's Avatar
    Yes you can as diesels only require a soot test, not an emmissions test as such.
    Not sure on the advantages or disadvantages.
    Regular Member smoggydovit's Avatar
    Jun 2009
    Kilmarnock
    Yup, legally you can run without the cat.
    Some people say de-catting a derv can damage the turbo........others say thats rubbish.
    As for gains............throttle pick up improves as does the noise but not sure about bhp/torque figures.......
    HTH
  1. dpf removal, not the usual question
    By J P S in forum Engine & Drivetrain
    Last Post: 12th June 2012, 16:21
  2. unuseal egr valve removal related question ??!!??
    By shaney_87 in forum Diesel Engine related
    Last Post: 15th February 2012, 14:12
  3. Front Spring Removal Question
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 01:46
  4. Vaux-Com / Op-Com question - Screen change question
    Last Post: 16th May 2010, 23:54
  5. Rear Badge removal done and Grille question
    By mikey68 in forum Styling
    Last Post: 3rd July 2008, 10:58
