Results 1 to 10 of 14
Thread: rear fog lights fuse
    Nov 2009
    newcastle
    Default rear fog lights fuse
    for some reason my rear fogs wont come on its not the bulbs
    i fitted lexus style rear lights and ever since the fogs are not coming on.
    i also get the check rear fog lights in the dash screen
    does anyone know where the fuse is or anything else it could be ??
    Have you modified the wiring?
    If not, then examine the offside bulb and replace with a new bulb
    Nottinghamshire
    Beaten to it, but anyway...
    The bulb check works by running a small current through the bulbs that it monitors. When it indicates that a bulb has failed, it either means that the bulb will probably fail soon (it must be sensitive enough to pick up the filament starting to go), or that the circuit is open - i.e. the bulb has already failed, there is no bulb fitted, or there's a wiring problem.
    I haven't had a fuse blow so I don't know if that would cause a bulb failure warning. Does the manual say which fuse is for the fog lights?
    If there is a seperate rear fog light fuse, could you have shorted the circuit out and so blown the fuse accidentally when fitting the new lights?
    Also, did the new lights come with a bulb holder or did you use the existing one? If it is new, check that the wiring is OK with a circuit tester - disconnect the car's wiring then put the circuit tester on the fog light terminal and negative terminal and you should get a circuit as long as there's a good bulb fitted.
    Nov 2009
    newcastle
    the rear lexus lights come ready to go all i needed to do was put the bulbs in
    and plug them in. bit funny how both the fog lights dont work that why i thought it must be the fuse
    il try some fresh bulbs tomorrow see if that fixes it as i used the bulbs out of my old lights
    Regular Member yadziyad's Avatar
    London
    Quote Originally Posted by stevelee View Post
    on vecs the rear passenger fog light doesnt work, so the bulb might just be out on the right
    Nov 2009
    newcastle
    Quote Originally Posted by yadziyad View Post
    ah never knew that thanks for the tip
    Nov 2009
    newcastle
    confused
    still cant get my rear for working,
    put new bulb in still nothing checked current its ok
    checked every fuse in the back rear fuse box none are blown its really got me stumped as to why it wont come on
    11 Post(s)
    Try the original light clusters. If the rear O/S fog works again, then it's the Lexus style clusters that's the problem.
    It's probably taken offence to them being so ugly...
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Maybe you have answered your own question here.
  1. Rear fuse box
    By nikroc in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2011, 13:43
  2. rear fuse box Q?
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2011, 17:03
  3. Number Plate Lights Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2010, 17:09
  4. rear fog light fuse
    By thedrive in forum Vectra C / Signum Troubleshooting
    Last Post: 4th October 2009, 19:11
  5. Rear window fuse
    By steviemac74 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2008, 00:57
vauxhall signum fog light fuse
2005 vectra foglight fuse location
fog light fuse on a vauxhall vectra c
vectra c gts fog fuse
