Thread: help what next
    Regular Member pitsmoor21's Avatar
    Apr 2008
    sheffield
    Angry help what next
    Just had the engine change and now have the power steering light on and no power steering. Took it to auto electrician who could not get a signal from it so he said theres either no power getting to the spower steering pump or the pump is knackered.
    The pump in my car is at the back of the engine to the left looks a bit like a plastic milk bottle wiht a black cap should i check the fluid levels would that cause the problem.
    Im only an electrician so any help would be gratefull
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you checked all the leads have been plugged back in after the engine change
    May 2006
    scotland
    Does your car need reprogrammed by the dealers??
    Worcs/Staffs/Westmids (ish)
    I'd say something wasn't put back correctly, the engine like anything really should have been removed by disconnecting everything one at a time carefully noting where each part goes, then reassembled in reverse order.
    Some people don't do this, they get to the end and go "oh i've got 6 screws left over" *scratch head* "nevermind probably not important".
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by pitsmoor21 View Post
    The pump is located under the drivers side wing behind the front bumper, you sure its at the back of your engine. Yes check the fluid but as said sounds like something might be unplugged
    Apr 2008
    sheffield
    if the power steering pump looks like a white plastic bottle with a black plastic lid its at the back of my engine and its going to my mechanic mate saturday to check connections also would an engine change need the power steering pump re programming as its the same one that was originally there with no problems before
    Yes that is your power steering pump and bottle mounted behind the engine, its the compact version and the same as mine.
